04 Aftermarket Header rattling
Got the new DC Sport 4-2-1 ceramic header put on today. I didn't do it myself since I don't have the necessary requirements, but it was done by a custom shop run by ex-Honda/Acura techs who have done most of my work so far. When it was done, I went and took it for a test drive. It was making a rattling sound, just below me, a separate noise itself from the exhaust tone. It seemed like something to do with the header->cat hookup. It only happens above 2.5k RPMs or so. When I was at the Honda shop, they thought it might be a loose gasket, so I'll check it out soon. Any thoughts?
Another weird thing. I know for a fact on my auto that my rev limiter is set at 6.5k RPMs which is redline. So today, on my way home, just for giggles, I took it out on my street and ran it up through 2 gears "manually". Through first, I blew right through my rev limiter and hit 7.5k RPMs. It shocked me so much, and I knew it wasn't an anomally because I lost traction in the shift, which never happens (and headers cant add enough power to do that lol). Any comments on that either?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 »</TD></TR><TR><TD CLASS="quote">It probably just the heat sheild for the catalytic converter rattling.</TD></TR></TABLE>
DING DING DING DING
We have arrived at the correct answer. just have them wrap the heat shield with a steel band and problem solved.
DING DING DING DING
Ok, talked to them on the phone, taking it into tomorrow to get that done. I had a friend rev it for me and I KNEW it was coming from the header/cat area.
Any comments on blowing thru the rev limiter?
it may have cut fuel, but i definetely felt/noticed that i was going thru redline, which i've never done before. I tried doing it again, couldn't do it, must have been a momentary problem with the ECU.
We have a Winner!
They probably busted something loose when they let the exhaust hang.
It's time for a couple of Super-sized worm style Hose Clamps...
P
P
USDMSiR
Aug 14, 2006 05:29 AM
