How To Install ???
Ok I wanted to know how to install a Slim Line fan onto my PWR 1/2 radiator. I have a Full Race traction bar as my setup. I need help to install the fan so I can be done with the whole traction swap. I hope someone with the same setup can help me out. Thanx
What's your question? Installing a slim radiator fan is really easy, it's a two wire set-up. One is a hot wire and the other is ground. Either hook it up to the stock rad plug, or run a toogle switch. For mounting the fan, it's as easy as pulling the mounting zip-ties throught the fins. I hope that was your question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 »</TD></TR><TR><TD CLASS="quote">What's your question? Installing a slim radiator fan is really easy, it's a two wire set-up. One is a hot wire and the other is ground. Either hook it up to the stock rad plug, or run a toogle switch. For mounting the fan, it's as easy as pulling the mounting zip-ties throught the fins. I hope that was your question.</TD></TR></TABLE>
I know about the toggle switch since I had that before on my old radiator fan. My question is on how to mount the fan onto the radiator. How do I go about on the zip-ties ?
meanTheDope
21
Aug 24, 2016 09:20 AM
