LS tranny vs GSR tranny
Old Mar 15, 2006 | 07:09 AM
the_one_6682's Avatar
Default LS tranny vs GSR tranny
i have a 93 hatch with an LS engine in it. Will there be any difference in performance with an LS trans vs. a GSR transmission? Will i notice the change??
Old Mar 15, 2006 | 07:11 AM
Micha's Avatar
FAILWGN
Default Re: LS tranny vs GSR tranny (the_one_6682)
You will notice it from 3rd gear up. What are your plans for the car?
Old Mar 15, 2006 | 07:20 AM
90DAkid's Avatar
don't ls tranny has longer gears? and gsr like in the middle of type r and ls?
Old Mar 15, 2006 | 07:24 AM
Default Re: LS tranny vs GSR tranny (Blu99teg)
Well hopefully if the funds are right then i want to build an LS vtec with a 75 shot nitrous kit. hopefully....low 13s??
Old Mar 15, 2006 | 07:27 AM
Micha's Avatar
FAILWGN
yeah. Just get a GSR tranny. You will like it. My buddies GSR is fun to drive(of course).
Old Mar 15, 2006 | 08:04 AM
Sic_DA_Nine's Avatar
gsr tranny has shorter gears
the short gears let you accelerate faster through gears. on freeway tho, you will be revving higher
Old Mar 15, 2006 | 08:14 AM
iH8RICERZ's Avatar
Default Re: (97dC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dC4 &raquo;</TD></TR><TR><TD CLASS="quote">gsr tranny has shorter gears
the short gears let you accelerate faster through gears. on freeway tho, you will be revving higher</TD></TR></TABLE>
only downside to have a gsr/itr/b16a trans....if you like cruising at 80mph, then your tach reads 4k+ rpm...unlike the ls trans 5th gear. You could be crusing at 90+ before your motor revs to 4k!
Old Mar 15, 2006 | 08:32 AM
Ichigo's Avatar
makes you faster! you should get it. It would be more fun to drive with.
Old Mar 15, 2006 | 09:42 AM
RaceMyGhost's Avatar
Default Re: (Ichigo)
if you're going to be doing a lot of drag racing, go with the typeR or gsr tranny, but if you're looking for higher top speed or its just your everyday driver, go with the ls tranny
Old Mar 15, 2006 | 10:20 AM
RaceCarRyne's Avatar
Default Re: (RaceMyGhost)
my buddie had an ls with a gsr tranny in his del sol.. not bad.. def better than the ls tranny.. i think it ran a 15 flat on street tires.. b16 would liven it up a ton but you also gotta remember the high Rs while highway crusing..
Old Mar 15, 2006 | 10:26 AM
Lauj87's Avatar
try searching...theres tons of threads on these!
tegasaurus
Feb 5, 2007 07:29 PM
H.A.R.T B18C1EG6
Apr 27, 2006 09:53 PM
flyingduck04
Mar 10, 2005 09:22 AM
99REDGSR1
Apr 17, 2004 05:46 PM
egg_baLLa
Feb 17, 2004 12:34 PM
