Need some help on a 92cx with LS
Old Mar 15, 2006 | 06:13 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Need some help on a 92cx with LS
Heres the thread
https://honda-tech.com/zerothread?id=1559867
Just need some help pretty quick with this car, and there seems to be no traffic in hybrid
Old Mar 15, 2006 | 07:00 AM
I am USDM's Avatar
Default Re: Need some help on a 92cx with LS (Stunna BEN)
thanks ben
Old Mar 15, 2006 | 07:45 AM
mwieczorek43's Avatar
Default Re: Need some help on a 92cx with LS (I am USDM)
did you get this taken care of yet? I'm running an 97ls in my 93dx so I've personally done them (and a few friends too).
it's just like 92civichatch1 said in the thread you posted. Im actually the one who took him through the steps on that swap. Its all plug and play man, you DO NOT need to swap dizzy etc. So im assuming it isn't b/c the obd differences. I had a bad ecu... maybe double-ckeck the ecu..? Are you throwing any codes at all? I had a bad o2 and bad map-sensor that kept mine from starting-up. i replaced the o2...
the one thing he didn't mention in his thread is the map sensor change (i don't think he had to do it). On my 93dx, the map is bolted onto the fire-wall, on the LS the map is located on the top of the IM. Just take those wires (3 i think) from the stock location and run them to the correct map location. Im not sure if your car has this same map issue....? i think they're different from year-to-year...? keep us updated and let me know if this helps
Old Mar 15, 2006 | 09:43 AM
Default Re: Need some help on a 92cx with LS (mwieczorek43)
bump for this guy.
Plus I spent like 5 minutes writing out that response
Old Mar 15, 2006 | 02:09 PM
Stunna BEN's Avatar
Im not sure if he tried or fixed anything yet?
Know anything daniel?
Anyone else have any other input?
Old Mar 15, 2006 | 02:12 PM
Shaun's Avatar
why didnt you just use the cx harness and rewire the IACV? sounds like timing
Old Mar 16, 2006 | 05:10 AM
I am USDM's Avatar
Default Re: (Shaun)
thanks for the input guys, im gonna work on it today because i have a little free time
Old Mar 16, 2006 | 05:49 AM
Stunna BEN's Avatar
Default Re: (I am USDM)
Fall_out_boy_99
Aug 28, 2010 10:09 AM
tdub1904
Nov 2, 2009 07:32 AM
AnthraxVX
Mar 23, 2006 10:29 PM
Superhatch
Mar 26, 2002 05:26 PM
