msd 6al rev limiter chips
the msd 6al comes with pre-chipped rev limiters at 5k, 6k, 7k and 8k...which is obviously way lower than the stock limiter at 8900 on Gs-r's. Will not running a chip in the 6al allow the motor to retain the stock limiter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmv38 »</TD></TR><TR><TD CLASS="quote">It will eliminate the stock limiter with-out the pills in it. go to summitracing.com and order the one you want.</TD></TR></TABLE>
Stock rev limiter will still be there. The ecu controls that
the stock rev limiter will still be there unless you chip the ecu. THe MSD is a spark cut style limiter, which cuts the ignition out. the stock style is a fuel cut style, which cuts the fuel out. MSD makes a dial adjustable module you can plug in and adjust your limiter by turning a ****.
i got the msd full ignition as a deal, however i've been hearing there are a lot of problem
that come with it and stock ignition is good enough...so far so good there are no problems. i just hate how the highest chip is 8k...and i don't want to pull that chip and eliminate the stock limiter and consequently blowing my motor from over rev
Guest
Posts: n/a
you can make your own custom rev limit chips for really cheap... all they are, are a resistor you can buy at radio shack. I use to have a formula to figure out what resitance for what rpm but i made all my chips and have no more use for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg »</TD></TR><TR><TD CLASS="quote">Why do you need an aftermarket ignition? What is done to your car? </TD></TR></TABLE>
Just because the stock igntion can handle over 500hp doesn't mean you shouldnt upgrade. Stock honda motors can handle a turbo but people still build them up to be safe.
