d16yb
what all do i need for the swap for an ef?? im kinda confused because this is my first honda that i will be swapping. i already posted this but i was looking for more solutions and answers.
thanx
thanx
Thers nothing wrong with the y8, i swapped one into my crx and installed a home made turbo kit i put together myself, i have been running a consistent 9psi since june and have been driving hard with no problems. a y8 swap is pretty straight forward, the easiest way is to use the crx si tranny, distributor, injectors, and ecu. Keep the y8 intake manifold, all the sensors hook up, the only modification is extending the Map sensor plug from the firewall to the throttle body. everything is pretty straight forward.
drewboy
Feb 22, 2005 05:19 PM
95civicSirCoupe
Jun 4, 2004 05:27 AM
