75 shot ITR bottom end????
Old Apr 1, 2002 | 01:23 PM
SCsol's Avatar
Default 75 shot ITR bottom end????
hello there guys i have a ITR bottom end with a set of 63402 crower vtec cams and a 11 lb flywheel will the ITR bottom end handle a 75 shot form a Zex kit?
i have a MSD digital 6 and will retard the timing 3*
any information would be great
Old Apr 1, 2002 | 01:38 PM
AssPenny's Avatar
Default Re: 75 shot ITR bottom end???? (lowsol)
Yes, but will your plugs handle it? Ask RealTypeR for details.... he ran it on his R for some time till it had a little issue.
[Modified by AssPenny, 5:38 PM 4/1/2002]
Old Apr 1, 2002 | 01:40 PM
non-VTEC's Avatar
it should take it.............make sure you run like 2 or 3 step colder plugs and watch the timing advance.......
i'd like to see a dyno of that type of set-up
Old Apr 1, 2002 | 01:43 PM
nfn15037's Avatar
Default Re: 75 shot ITR bottom end???? (non-VTEC)
IM Pinhead, he ran a direct port 100 shot for a while, seemed to handle it fine. Now the tires on the other hand.....well, you get the point
Old Apr 1, 2002 | 01:48 PM
Pinhead's Avatar
New User
Default Re: 75 shot ITR bottom end???? (nfn15037)
The tires weren't THAT bad just don't spray in 1st on the street lol......don't ping your rev limiter and run 7 series NGK's and retard your timing 3 degrees and FUEL FUEL FUEL....get a fuel pump and a fpr and you'll be good to go
Old Apr 1, 2002 | 01:56 PM
SCsol's Avatar
Default Re: 75 shot ITR bottom end???? (Pinhead)
ok thanks i have a holley fuel pump in there and a mugen chiped ECU so i should have enought fuel and a MSD digtal 6 so i will retard the timing 3* and run a 7 NGK do they come in platiunm? anything eles i should know
Has anyone ever blown up a ITR bottom end with a 75 ZEX shot?
Old Apr 1, 2002 | 01:58 PM
AssPenny's Avatar
Run copper, that way if it gets too hot it melts the plug and not your piston.
Old Apr 1, 2002 | 02:12 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: 75 shot ITR bottom end???? (AssPenny)
check your IM - don't just jump to a 75 shot, start lower and see how your car handles it.....you know your car better than anyone else.
Old Apr 1, 2002 | 02:37 PM
lePetitePrince's Avatar
Default Re: 75 shot ITR bottom end???? (RealTypeR)
hey, I like to konw how are those cams ?? are they good?? any dyno plot???
can you describe in detail how those cams are working??? cons and pros?
Old Apr 1, 2002 | 02:38 PM
Default Re: 75 shot ITR bottom end???? (lePetitePrince)
The crower Nitrous cams are good (from what I hear) - never used them myself
Old Apr 1, 2002 | 04:29 PM
SCsol's Avatar
so far i just put the motor together and ran it today, she pulls hard, make sure you install the crower springs and some portflow retainers. rubber all the way thru 1st and some second it has to go to the dyno to get the most out of them i think for the cash there good cams
XzIpK
May 13, 2007 07:16 PM
Mattmob
Dec 20, 2004 05:54 PM
sicklexus1
Jan 29, 2003 03:30 PM
grocerygetter
Aug 26, 2002 09:23 PM
SCsol
Apr 1, 2002 02:07 PM
