getto rigged ecu?
Old Mar 14, 2006 | 08:12 PM
zacatkings's Avatar
Default getto rigged ecu?
ok well i aquirred an ecu (p28) that has been chipped. I am not questioning that. I am wondering about this just soildered in wire. It doesnt look right and wondering if it will cause any problems. ecu guros lets go.
Old Mar 14, 2006 | 08:14 PM
jdmjaser's Avatar
Default Re: getto rigged ecu? (zacatkings)
oh my god...that is ghetto! get that fix!!!
Old Mar 14, 2006 | 08:15 PM
zacatkings's Avatar
Default Re: getto rigged ecu? (jdmjaser)
how do i fix it or get it fixed?
Old Mar 14, 2006 | 08:26 PM
zacatkings's Avatar
ttt
Old Mar 14, 2006 | 08:28 PM
EGwhat!!!'s Avatar
i dont think you can but i could be wrong though
Old Mar 14, 2006 | 08:29 PM
Lewy. Dee Ayy's Avatar
is that soldering wire connecting w/e it is thats being connected?
Old Mar 14, 2006 | 08:32 PM
Relic1's Avatar
first off... DEAR F'KING GOD!!!
that is D5, it acts as a sort of reverse battery protection, basically it shorts out causing the ECU fuse to blow if you put on your battery cables backwards.
Are you using that ECU? I hope not.
Placing a peice of wire in that location will make power - ground connection at all times. pop goes the ECU fuse. I'd bet the previous owner got mad, put in larger fuse, then pop goes the trace on the board. (not a good thing)
Cut the wire, you're better off without anything in it's place rather than a wire.
If you'd like it to be as close to original as possible, repair the blown trace (if it's blown) and replace the diode with a 5amp rectifier diode and it will be fine.
If you need help let me know, I can take care of it for you. All though I'm in chicago. There may be someone local that can help you out faster.
Old Mar 14, 2006 | 08:35 PM
zacatkings's Avatar
Default Re: (Relic1)
thank you very much
Old Mar 14, 2006 | 08:45 PM
Relic1's Avatar
BTW pretty much anyone on these lists should be able to help you get htat ECU back to the way it should be.
http://forum.pgmfi.org/viewtopic.php?p=23183
or
http://forum.pgmfi.org/viewtopic.php?t=3061
Old Mar 14, 2006 | 08:50 PM
zacatkings's Avatar
dont have a password cant look at those sites
Old Mar 15, 2006 | 07:10 AM
Relic1's Avatar
it's free to sign up, zero spam, and the site offers more info on a honda ECU than the average person can keep up with.
Old Mar 15, 2006 | 08:31 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">first off... DEAR F'KING GOD!!!</TD></TR></TABLE>
x10
I think I'd try and get a refund for that ECU, if you can. The PGM-Fi site Relic1 linked you to, is indeed a great site.
I personally wouldn't bother dickin' with it...and I work with stuff like that for a living. If that was considered a 'fix' by whomever messed it up in the first place, then you gotta wonder what else was done to it or what else this creative mind tried.
jspeccrx91
Aug 11, 2009 05:49 PM
94SuperLudeSI
Apr 20, 2008 06:10 AM
Spy1r
Mar 3, 2004 08:30 PM
killa_lude
Jan 10, 2004 12:45 PM
itr_alexx
Apr 22, 2002 05:55 AM
