ITR Sway in EK hatch?
Old Mar 14, 2006 | 06:56 PM
o2flow.net's Avatar
Default ITR Sway in EK hatch?
Just curious what is needed to fit an ITR rear sway in an EK hatch?? Will I need a ASR subframe or can the stock subframe handle 22mm without tear-out?
Old Mar 14, 2006 | 07:00 PM
pdiggitydogg's Avatar
yes, you need bracing like the asr piece or full comptech
Old Mar 14, 2006 | 07:16 PM
o2flow.net's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">yes, you need bracing like the asr piece or full comptech</TD></TR></TABLE>
you mean something like this?
http://cgi.ebay.com/ebaymotors...&rd=1
Old Mar 14, 2006 | 08:25 PM
cambopheonix56's Avatar
Default Re: (o2flow.net)
no, this
http://www.kteller.com/store/p.../1537
Old Mar 14, 2006 | 08:54 PM
comptech is the same thing, basically
Old Mar 15, 2006 | 11:11 AM
o2flow.net's Avatar
what about the front? Can I use an ITR sway in the front also?
Old Mar 15, 2006 | 11:40 AM
6SPD_EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o2flow.net &raquo;</TD></TR><TR><TD CLASS="quote">what about the front? Can I use an ITR sway in the front also?</TD></TR></TABLE>
NO!!!!..... but you can use OEM Si/CTR (they are the same) sway 26mm
Old Mar 15, 2006 | 11:52 AM
o2flow.net's Avatar
Default Re: (adirondackR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR &raquo;</TD></TR><TR><TD CLASS="quote">NO!!!!..... but you can use OEM Si/CTR (they are the same) sway 26mm </TD></TR></TABLE>
sweet, does it bolt right up or do I need hardware?
Old Mar 15, 2006 | 12:25 PM
6SPD_EK's Avatar
sweet, does it bolt right up or do I need hardware?</TD></TR></TABLE>
you need Si front LCAs, forks & D-brackets with bushings then it will bolt up....might as well get '99-'00 si F&R brakes too
.:Made in OC:.
13
Feb 20, 2007 04:05 PM
Airbag Club
Northern California (Sales)
Oct 1, 2006 07:35 PM
damnecheck
Jul 5, 2005 03:40 PM
blackstar
Dec 15, 2004 05:46 AM
SW20 MR2
Aug 20, 2002 07:39 AM
