Need Help ASaP. Oil pressure and temp gauge install....
Old Mar 14, 2006 | 06:12 PM
STEV3-O's Avatar
Default Need Help ASaP. Oil pressure and temp gauge install....
I got the blox oil temp and presure gauges. I got a sandwich plate that i also bought from blox. Now for the oil pressure unit i cant get it to fit without taking outt he stock oil pressure unit. I was wondering if i can take out the stock unit and add it to the sandwich adapter and just connect it there and then just block off the stock location ??? any inputs? also for wiring, do i groung the presure unit and then run the red wire to the sensor>???? as for tempterature i think i got it right, just run that red wire to the sensor.
See no space:
heres how im thinking of doing it:
Old Mar 14, 2006 | 06:24 PM
huntarrr's Avatar
Default Re: Need Help ASaP. Oil pressure and temp gauge install.... (STEV3-O)
Try putting the oil pressure sender unit where the temp sensor is and rotate the sandwich about 90* counter clockwise. Look like it'll work like that.... I made it work somehow...
Old Mar 14, 2006 | 07:41 PM
STEV3-O's Avatar
Default Re: Need Help ASaP. Oil pressure and temp gauge install.... (vsm98civic)
nope, ive tried all the ways.
Old Mar 14, 2006 | 08:53 PM
STEV3-O's Avatar
Old Mar 14, 2006 | 09:20 PM
CivicSiRX's Avatar
wat i did for my autometer oil pressure was, run a stainless steel braided line from the stock oil pressure location up to the firewall about 6-7 inches, then i tee it off, one end for the pressure sending unit, the other end for the oem unit. works great for the last 2 years.
Old Mar 14, 2006 | 09:37 PM
Br1anPham's Avatar
If you block off the stock oil pressure sensor, I would connect the OEM plug somehow to your new oil pressure sensor as well. And if you do, I don't see a problem with that setup.
Br1anPham's Avatar
Default Re: (CivicSiRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRX &raquo;</TD></TR><TR><TD CLASS="quote">wat i did for my autometer oil pressure was, run a stainless steel braided line from the stock oil pressure location up to the firewall about 6-7 inches, then i tee it off, one end for the pressure sending unit, the other end for the oem unit. works great for the last 2 years. </TD></TR></TABLE> What happened after 2 years?
Old Mar 14, 2006 | 10:14 PM
CivicSiRX's Avatar
Default Re: (Br1anPham)
lemme rephrase that. works great for 2 years and counting..........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Br1anPham &raquo;</TD></TR><TR><TD CLASS="quote"> What happened after 2 years?</TD></TR></TABLE>
Old Mar 14, 2006 | 11:02 PM
dat_flip's Avatar
You should have a bung welded on your oil pan for your oil temp sensor.
Old Mar 15, 2006 | 06:58 AM
huntarrr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STEV3-O &raquo;</TD></TR><TR><TD CLASS="quote">nope, ive tried all the ways. </TD></TR></TABLE>
Then do it the way you have in the last pic.....
Old Mar 15, 2006 | 11:24 AM
STEV3-O's Avatar
shouldnt be an issue? Just plug the stock location with a brass plug?
Old May 17, 2006 | 09:13 PM
b20izzle's Avatar
wats that clip for on the sender unit? is that the ground?
Old Oct 3, 2006 | 02:02 PM
djnikko's Avatar
Default Re: Need Help ASaP. Oil pressure and temp gauge install.... (b20izzle)
What size thread is the sensor out of interest? Are they likey to be the same on all honda's? Im running a H22
OGMatt
Aug 15, 2011 01:11 PM
tundra2000
Sep 27, 2010 06:22 PM
SoFresh1189
May 3, 2010 06:16 AM
velisma
Jan 30, 2010 08:24 PM
Juccord
Jul 11, 2004 07:41 AM
