b16a ecu question
Old Mar 14, 2006 | 06:09 PM
Chicano's Avatar
Default b16a ecu question
My vtec went out in my b16 eg...its a usdm b16, the wiring is similar to a 95 del sol si...code is 21 and there is no signal from the ecu to the vtec solenoid so I need a new ecu..my question is what ecu to get...which are compatible with a manual b16a motor...I am going to open it tomorrow to get the factory number but any help would be appreciated *edit* the ecu is a p30 sir ll b16a2 ecu**
Modified by skaterguy at 10:51 PM 3/15/2006
Old Mar 14, 2006 | 07:05 PM
civic2slo's Avatar
Default Re: b16a ecu question (skaterguy)
what ecu are you using? Usdm or jdm?
Old Mar 14, 2006 | 07:23 PM
Chicano's Avatar
Default Re: b16a ecu question (civic2slo)
usdm i believe
Old Mar 14, 2006 | 10:07 PM
Chicano's Avatar
help?
Old Mar 14, 2006 | 10:57 PM
civic2slo's Avatar
does it say p30-900 or p30-000? does it have an "a" like p30-a00?
Have you check you oil level of you engine? Make sure it filled.
Old Mar 15, 2006 | 04:13 AM
crxnj's Avatar
Check to see if maybe the vtec solenoid wire came loose before you go and purchase a new ecu..
But as far as an ecu to replace it,,A chipped p28 always works..Its kind of hard to find the obd1 del b16a3 ecus and jdm obd1 sir2 b16 ecus,,so look for a chipped p28 ..
Old Mar 15, 2006 | 05:40 AM
D16Z6TURBO's Avatar
Its not that hard cause I have a JDM P30 for sale!
Old Mar 15, 2006 | 09:31 AM
Chicano's Avatar
Default Re: (D16Z6TURBO)
its not a wiring problem I took it to a shop and they did a diagnostic on the car....so p28 and p30 will work? even if its jdm ecu on a usdm motor?
Old Mar 15, 2006 | 09:54 AM
IVI's Avatar
IVI
Default Re: (skaterguy)
just curious... how exactly did you check if the solenoid is getting a signal?
which shop did the diagnostic on the car?
jdm or usdm ecu will work, obd1 or obd2 would work, but then you may need a conversion harness.
i wouldn't look at the ecu just yet.
Old Mar 15, 2006 | 09:57 AM
bmoua's Avatar
chipped p28 bro...you cant go wrong..
Old Mar 15, 2006 | 01:50 PM
Chicano's Avatar
Default Re: (bmoua)
ok its a p30 sir ll b16a2 ecu so will a p28 chipped ecu work aswell? or do I need a p30 exactly p30-000
Modified by skaterguy at 3:34 AM 3/16/2006
Old Mar 15, 2006 | 02:15 PM
civic2slo's Avatar
any p30 as long as its an 5 spd or chipped automatic p30 (jdm). You can use a usdm p30 but hard to find and $$$(shameless plus...Hey I selling a usdm p30 lol). When you can use a chipped p28 with a p30 program.
Old Mar 15, 2006 | 03:13 PM
Chicano's Avatar
Default Re: (civic2slo)
Old Mar 15, 2006 | 03:18 PM
jadugartir's Avatar
p28 + hondata = sechs
Old Mar 15, 2006 | 04:06 PM
spoonracer84eg's Avatar
Check your oil level just in case. Vtec wont activate with low oil pressure.
Old Mar 15, 2006 | 04:07 PM
Chicano's Avatar
Default Re: b16a ecu question (spoonracer84eg)
one of the first things i checked...its fine...know its the ecu so i need to be sure which will work
Old Mar 15, 2006 | 05:27 PM
D16Z6TURBO's Avatar
hit up phearable.net he can set you up with a chipped P28 that will work fine or a P30 will work as well
kp
Engine Management and Tuning
16
Feb 13, 2009 09:51 AM
JKov240
Feb 18, 2007 04:37 PM
JDM B16A
31
Apr 11, 2006 05:01 PM
NA-Cutie
Northern California (Sales)
Mar 7, 2006 08:16 AM
astroxtc
Nov 1, 2005 09:02 PM
