95 integra ls cam timing
Old Mar 14, 2006 | 04:44 PM
pchris52's Avatar
Default 95 integra ls cam timing
i have a 95 ls in a 93 hatchback i think the cam timing is off because at 5500 to 6000 the motor bogs out i have gone down the list of checkin the ecu, ignition timing, clogged injectors, fuel rail pressure, and the tach being off ( this being stupid cause you know your hitting redline regardless wut a tach says) an d the last conclusion is the timing is off on the cams, it idles fine just when i'm on it it wont go any farther then 5500 to 6000 an feels likes its choking? was wondering if anyone had the stock specs on the ls cam timing so i can check an reset mine if needed?
Old Mar 14, 2006 | 05:32 PM
pchris52's Avatar
Default Re: 95 integra ls cam timing (pchris52)
can anyone referr a link or a topic related link on hear to this problem, or does somone have a refrence for the timing
Old Mar 14, 2006 | 07:15 PM
JimBlake's Avatar
Here's how to check the cam timing...
Remove the upper timing cover so you can see the sprockets. Rotate the engine forward (counterclockwise) by turning the CRANKshaft pulley. If you take the spark plugs out you can probably turn it by hand.
There's arrows on the camshaft pulleys. When they're pointing sorta upwards, watch the crankshaft timing marks. There's a set of three notches together, then to the right there's a single notch. Line up the lone single notch to the pointer molded into the lower timing cover.
The arrows on the camshaft sprockets are only approximate. The REAL timing marks are like little dimples out at the sprocket teeth. There's 2 on each sprocket, and they should all 4 line up straight across. You can lay a strait-edge across the centers of the camshafts & across all 4 of those little dimples.
With tolerances & belt stretch, they're not usually PERFECT. As long as the marks are on the tooth thats closest to being lined up.
Old Mar 14, 2006 | 08:20 PM
pchris52's Avatar
Default Re: 95 integra ls cam timing (JimBlake)
from the description of wut i was tellin everyone does it sound like the cams are off?
Old Mar 15, 2006 | 03:40 AM
JimBlake's Avatar
Could be, but why worry about that when it's pretty easy to actually check. Then you'll KNOW whether the cam timing is OK.
Old Mar 15, 2006 | 08:23 PM
pchris52's Avatar
wow appreciate it who ever owned the motor before me had them way advanced actaully scary to how close they were to were they could of detinated at higher rpms
Old Mar 16, 2006 | 08:57 PM
pchris52's Avatar
F*&^K!
it still wont RED LINE!
ok here is the chck list of wuts been checked an rechecked:
ignition timing
cam timing
fuel rail
injectors
fuel pump
ecu
and distributar
its a b18a1 set up for obd1
running on a 94 ls p75 computer anyone know wut might be goin on with this motor?
Old Mar 17, 2006 | 03:40 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pchris52 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 95 ls ...</TD></TR></TABLE>That would be a B18B1, wouldn't it?
(Not that it matters for anything said so far...)
Old Mar 17, 2006 | 10:57 AM
pchris52's Avatar
i messed up reading the block an wrote the wrong date and it doesn't matter so uh lets see a solution not wut mistakes were written!
Old Mar 17, 2006 | 11:29 AM
pchris52's Avatar
Any ideas i cant turbo the car unless i have the motor running perfect and i want this projoct over with so i can hit the tack soon
Old Mar 17, 2006 | 01:32 PM
pchris52's Avatar
any thoughts guys?
Old Mar 18, 2006 | 07:42 AM
pchris52's Avatar
bump
Old Mar 19, 2006 | 10:33 AM
pchris52's Avatar
bump
Old Mar 20, 2006 | 08:15 AM
JimBlake's Avatar
Distributor rotor? Kinda strange, but as the rpms get high, the spark is more advanced. This moves the arc over towards one end of the rotor's tip. Look for deterioration over towards the leading edge of the rotor tip. (I'm really searching for possibilities.) It seems like you've checked everything...
How about the fuel pump? You say you've checked it, but do you mean actual flow rate & pressure? Or just checked that it's running?
dividedas1
Jun 4, 2009 10:49 AM
stevescivic
Sep 6, 2006 10:02 PM
donnjuan2point2
Mar 11, 2004 10:49 AM
kerby116
Mar 10, 2004 07:07 AM
b00stedbyFastrax
Mar 17, 2003 06:35 AM
