?intercooler install question?
Old Mar 14, 2006 | 01:46 PM
mawkiemarc's Avatar
Default ?intercooler install question?
ok my 90 si hatch d16a6 is comin along just fine til now. i was wonderin if there is anyone out there that could help me find out more info on how to install my intercooler and whats involved. everytime i search i get topics i dont need, maybe im not inputin the corect words i dont know. but if anyone could help me that would be nice, THANKS
Old Mar 14, 2006 | 01:48 PM
RCautoworks's Avatar
Default Re: ?intercooler install question? (mawkiemarc)
Mock it up, postion it, weld brackets, connect charge pipes.
Old Mar 14, 2006 | 02:53 PM
ryan89crx's Avatar
Default Re: ?intercooler install question? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Mock it up, postion it, weld brackets, connect charge pipes.</TD></TR></TABLE>basically about it...
you need to cut your bumper, i wasnt able to fit mine behind the plastic. also you need to relocate your washer bottle depending on how you are routing piping. i found the easiest way is through the hole that the a/c can sits. then just run piping down the hole and around the front and the same for the passenger side. actually its really simple
Old Mar 14, 2006 | 02:59 PM
Mugencrxsir1's Avatar
Default Re: ?intercooler install question? (ryan89crx)
there's no need to cut anything, just do a lot of measuring, and order a intercooler that fits your front bumper situation/horse power goal.
Old Mar 14, 2006 | 03:03 PM
ryan89crx's Avatar
Default Re: ?intercooler install question? (Mugencrxsir1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">there's no need to cut anything, just do a lot of measuring, and order a intercooler that fits your front bumper situation/horse power goal.</TD></TR></TABLE>well mine is onle 2.75" thick and there was NO way that it would fit behind the stock bumper...
maybe if it wasnt as long and it was a backdoor style i could have move it back a bit and kept the front bumper intact
Old Mar 14, 2006 | 03:18 PM
Groovinator's Avatar
your probably gonna have to do some cutting in order to get an IC to fit.
my setup is a 31x6x2.5 and i needed to cut the bumper beam, and the grill in order to get the damn thing in there. then after i had to remove the washer bottle and run a much smaller one inside the engine bay (looks kinda cool IMO) jut to get the piping in there.
i hope you know someone with a plasma cutter, or at least a torch
Old Mar 14, 2006 | 04:32 PM
Default Re: ?intercooler install question? (Groovinator)
Yes I agree that for a stock bumper you will need to cut the bumper, but you could always figure something out. I do have an aftermarket bumper that allows me to have a lot more room.
Old Mar 14, 2006 | 05:28 PM
i think you still need to cut the beam though. unless you can find a way to put it in behind the support beam that runs in the middle of the car from the sub frame to the upper rad support.
Old Mar 14, 2006 | 06:26 PM
ryan89crx's Avatar
i never had to cut the bumper beam on mine, just plastic
Old Mar 15, 2006 | 05:06 AM
mawkiemarc's Avatar
yeah i already gut the beam, and with the bumper on it fits. i was just wondering about the piping. like how it would route back from the intercooler. bc it looks like those brackets where u can pull it from are in the way. i dont kno tho.
Old Mar 16, 2006 | 12:56 PM
Default Re: (mawkiemarc)
and i just had my bumper off to do some work. if i had seen this thread earlier i would of snapped some pictures.
Old Mar 16, 2006 | 02:09 PM
mawkiemarc's Avatar
thanks anyways man its aight. well i guess my true question is, is there any thread that has covered the install or is there anyone who has pic's that could maybe help me....thanks.
Old Mar 16, 2006 | 03:27 PM
green91's Avatar
I had to cut my bumper plastic and my bumper support to fit a fairly small intercooler.
Old Mar 16, 2006 | 03:35 PM
ryan89crx's Avatar
hmmm, maybe its because my car is an HF and the support is smaller that i didnt have to cut the support
Old Mar 16, 2006 | 11:06 PM
mawkiemarc's Avatar
well i tried to find some pix on HT, couldnt but found help on turbod16.com so thanks anyways guys, 1
Old Mar 16, 2006 | 11:52 PM
ef92b's Avatar
couple of turbo installs from HT members:
https://honda-tech.com/zerothread?id=1384961
https://honda-tech.com/zero...age=2
Old Mar 17, 2006 | 05:45 AM
bbrian's Avatar
on my 91 hatch how would i do about takin the bumper off without havin to take the support off with it , cause im tryin to figure out how to mount an intercooler too thanks
Old Mar 17, 2006 | 07:00 AM
Mr.Death's Avatar
Default Re: ?intercooler install question? (bbrian)
Here are some pics of my setup.
Old Mar 17, 2006 | 07:31 AM
mawkiemarc's Avatar
damn guys thanks, thats what i was lookin for. but how exactly is the IC help up? it looks like some black things on the bottom im not sure.?
Old Mar 17, 2006 | 03:04 PM
green91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbrian &raquo;</TD></TR><TR><TD CLASS="quote">on my 91 hatch how would i do about takin the bumper off without havin to take the support off with it , cause im tryin to figure out how to mount an intercooler too thanks</TD></TR></TABLE>
It cant easily be done, just take it all off as 1 unit and then remove the bumper cover from the support, then reinstal teh support if you need.
central_driver
40
May 25, 2007 06:38 AM
Blade121
Apr 16, 2006 04:50 AM
DIY Turbo
Mar 26, 2004 06:00 AM
ebp 99 si
Oct 5, 2003 07:04 PM
HXMan
Jun 5, 2002 09:38 PM
