blinging d4 light
Old Mar 14, 2006 | 11:15 AM
eli_s's Avatar
Default blinging d4 light
i did the code reading for the d4 light and it came up with 7, which has something to do with the shift control selonoid valve A, can anyone tell me where that is located... its on my 1995 honda accord coupe., 4 cylinder
Old Mar 14, 2006 | 11:31 AM
NAiL05's Avatar
Default Re: blinging d4 light (eli_s)
I think its the top one on your transmission. i think for accords the shift solenoids are located in the front of the tranny but i could be wrong. If you search around i think there is a diagram on the shift solenoids somewhere on here.
Old Mar 14, 2006 | 11:35 AM
YeuEmMaiMai's Avatar
standing in front of car left side top front of transaxle. remove and clean the screens and reinstall.
Old Mar 14, 2006 | 11:40 AM
eli_s's Avatar
thanks for the input guy, about to remove it now. ill let u know how it went
Old Mar 14, 2006 | 11:44 AM
P_Adams's Avatar
Here's an illustration of what you will be looking for. The 'A' pack (I believe) is the top-most of the two.
I have a suspission that the hard-set code may indicate a bad solenoid (and it will require replacing), but I would strongly recommend you first remove the solenoid packs and clean the servicable screens below them first.
It's cheap, and may actually help.
If it doesn't, you know what you've got to do.........
Good luck, hopefully this will address your problem
P
Old Mar 14, 2006 | 11:46 AM
P_Adams's Avatar
If you should need pricing on any of this:
http://www.hondaautomotivepart...USING
P
Old Mar 14, 2006 | 12:13 PM
eli_s's Avatar
thanks guys for all the help, i fixed it and it is running very smoothly. i was about to take the part off when i looked at the wired connector i notice that one of the wires was coming out of it. so i pushed it back in, snapped connectors back together. hooked up the battery and went for a drive. runs super nice and the light is out. thank u all for your help, honda tech is right on point
Old Mar 14, 2006 | 12:20 PM
P_Adams's Avatar
That's great. At least SOMETHING got fixed around here today!
And thanks for the Fix it Report. You findings will give us something else to offer as guidance.
P
Ruizj2195
Sep 9, 2017 06:31 AM
triniberg
Oct 25, 2012 05:45 PM
JDMishEK
27
Aug 23, 2007 08:29 AM
yellowEG
86
Jan 14, 2005 01:25 PM
azn_accord06
Dec 9, 2004 04:08 AM
