Del Sol Won't Start
If anyone can offer any advice I will be much appreciative.
I have a 93 Honda Del Sol 1.6L D16Z6. It will not start. I have checked numerous things and have narrowed it down to the timing. The problem is now I know it is not with the belt, but something electroical. All the steps I have taken in my manual have said replace with known good ECM and if symptom goes away replace. I don't know where I can try a good ECM and I don't have the money to buy one on a guess. Any ideas on how I can be sure of the problem?
Check your main parts of getting a motor to run.
Spark and Fuel.
One way to check for fuel, is to turn over the ign key, and wait untill you can HEAR the fuel system pressure up. Also get a friend to help you to check spark by hold a spark plug to the engine or fram while you crank the car over. This will give you some kind of idea on what parts to check. Also do a compression test.
Spark and Fuel.
a lot of times people think its the ecm when it turns out to be an ignition problem or fuel system related but if ur pretty sure its ecm u need a scanner to check your engines sensors. i dont really no the details about the scanner though sowwy
check if your gettin spark at all and fuel too...just yesterday night my roomates and i dropped in a gsr motor into a EJ1...took us 3 hours to figure out why the motor wouldn't start...ends up to be the timing...check your dizzy, see if you get any spark in the wires, then check the timing again...you might have the same problem as us bro...
i dont know if this will help you at all but my brother was having a problem hith his car starting also. people told him it was his timing. but it turned out to just be a map sensor.
dvpham
May 7, 2019 04:42 AM
Jdmgsr89
Aug 25, 2013 01:14 PM
JesusGLS
Jan 13, 2013 04:59 AM
