cat differences...
Old Mar 14, 2006 | 06:03 AM
ej2civic's Avatar
Default cat differences...
Ok, my car is civic ex ej1 -95.
now it has Engine B16A (sir2).
Does all 92-95 civics have the same cat?
Then what about 96-00? same as 92-95?
I'm having problems with smog, what would be the best cat in my situation?
Modified by ej2civic at 10:33 AM 3/14/2006
Old Mar 14, 2006 | 09:33 AM
ej2civic's Avatar
Default Re: cat differences... (ej2civic)
up
Old Mar 14, 2006 | 09:47 AM
AfricanBush's Avatar
i believe that the obd 2 cars have a diff cat. i think that the cat on the vtec cars from 92-00 is in the same location so it should fit either cat, but dont take my word for it. as far as which would be the best i would def go with a oem one if your having smog problems.
Old Mar 14, 2006 | 10:27 AM
ej2civic's Avatar
Default Re: cat differences... (AfricanBush)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AfricanBush &raquo;</TD></TR><TR><TD CLASS="quote">i believe that the obd 2 cars have a diff cat. i think that the cat on the vtec cars from 92-00 is in the same location so it should fit either cat, but dont take my word for it. as far as which would be the best i would def go with a oem one if your having smog problems.</TD></TR></TABLE>
OK thanks!
Does anyone know, does EG6(B16A) have different cat than ej1(d16z)?
Old Mar 14, 2006 | 10:47 AM
schardbody's Avatar
the differance in obd1 and obd2 cat is the length, im not sure which is longer, but either should work fine.
Old Mar 14, 2006 | 11:02 AM
Metalluthier's Avatar
Default Re: (schardbody)
It's longer for a reason, to compensate for mass air flow through the screen. I don't know what a shorter SOHC designed cat will do with a DOHC pushing more that a SOHC emmissions.
Old Mar 14, 2006 | 11:18 AM
ej2civic's Avatar
Default Re: (Metalluthier)
Umm, Ill call to honda dealer tomorrow and ask about the cat...!?
Damn, i bet that new OEM cat will cost $$$$
Old Mar 14, 2006 | 11:32 AM
blue92da's Avatar
just get yourself an SIR cat (99-00) and done with it. That is the oem cat made for the motor. Check on your local Honda club sites for someone trying to sell one used. As long as you can see light through the material in the cat it's good.
Old Mar 15, 2006 | 06:13 AM
ej2civic's Avatar
Default Re: (blue92da)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue92da &raquo;</TD></TR><TR><TD CLASS="quote">just get yourself an SIR cat (99-00) and done with it. That is the oem cat made for the motor. Check on your local Honda club sites for someone trying to sell one used. As long as you can see light through the material in the cat it's good.</TD></TR></TABLE>
Nope, Im sure no one has one here. See, I live in Finland... So I need to find VTi cat then...
Old Mar 15, 2006 | 07:50 AM
ej2civic's Avatar
Default Re: (ej2civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej2civic &raquo;</TD></TR><TR><TD CLASS="quote">
Nope, Im sure no one has one here. See, I live in Finland... So I need to find VTi cat then... </TD></TR></TABLE>
The company I got the motor, borrowed me SiR cat. No I passed smog
Thanks guys
ohhhmarkymarkEG6
Jul 18, 2006 09:23 PM
sicones
17
Apr 19, 2006 07:21 AM
Tegontoast
Jun 11, 2004 08:08 AM
EL Vap133
18
Jun 8, 2004 10:26 AM
