Boost a D15A2, bad idea?
Old Mar 14, 2006 | 01:18 AM
MotoCARR's Avatar
Default Boost a D15B2, bad idea?
I've got 180k on the clock, but am getting ready to do a full tune up with new gaskets, various oil seals, and a new OEM clutch. I haven't done a compression test yet, but if the cylinders are past 5%ish of each other, that answers my question . I'm just looking for a little more power for scooting around town. Won't be going to the track, the most extreme situation would be some highway driving. Would a S-AFC be ok for me to use with my applicaton? What's the max boost that I should not go past? I know the D15 has weaker internals than the D16, so I would imagine 3-5psi max? Everything will be stock except for an exhaust and maybe a Skunk 2 cam gear.
Modified by w8lifter21 at 4:55 PM 3/14/2006
Old Mar 14, 2006 | 02:39 AM
B18aHatch's Avatar
Default Re: Boost a D15A2, bad idea? (w8lifter21)
personaly i love boostin those cuz there so cheep and i like to see what happens when each one pops. but thats when im about to swap it out. and 3-5psi is just about nothing. that motor doesnt make much vacume or power to begin with. you shuld just find a used dry nitrous kit and throw it on there if you wana just "scoot round town"
Old Mar 14, 2006 | 04:38 AM
beyondspexj's Avatar
you can run about 7-10 pounds if your using good fuel management, have multiport fuel injection and a good tuner
Old Mar 14, 2006 | 05:24 AM
si0385.'s Avatar
Default Re: (beyondspecs_jamar)
it depends on the condition of your motor... thats prety high mileage to be boostin at all i would do a compression test first
Old Mar 14, 2006 | 05:48 AM
davens's Avatar
D15A2 or D15B2?
Old Mar 14, 2006 | 07:59 AM
MotoCARR's Avatar
My bad my bad, I have a B2 not an A2. If a compression test checks out I woiuld just be using the stock fuel system with the dual injectors. If I upgraded them to DSM 450's would that help? How about a S-AFC as engine management? I'm not looking to spend big $$$$, I only spent $375 for the car. Basically I am looking for the cheapest way to SAFELY boost my hatch.
Old Mar 14, 2006 | 08:05 AM
davens's Avatar
Default Re: (w8lifter21)
Here's a successful DPFI turbo to read about:
http://www.homemadeturbo.com/turbo_projects/d15b2/
Old Mar 14, 2006 | 09:43 PM
MotoCARR's Avatar
Anyone seen one with only the 2 injectors? ^^ he used 2 extra injectors in his setup
Old Mar 16, 2006 | 12:26 AM
MotoCARR's Avatar
Anyone?
Old Mar 16, 2006 | 11:44 PM
davens's Avatar
Using the stock DPFI just seems like a bad idea...asking for trouble.
It's a crappy design. Honda was willing to try it, but they quit using it entirely after just four years.
victoriasamantha
Jun 7, 2010 07:47 PM
mikeycivic
Apr 6, 2007 09:49 AM
hatchedzex
Jun 9, 2004 07:10 PM
hoya_10fintec
Jul 2, 2003 06:39 AM
genop
Mar 7, 2003 01:20 AM
