need help identifying head...
Old Mar 14, 2006 | 12:04 AM
methos713's Avatar
Default need help identifying head...
here are some pictures...was told it was a 98 itr head. Plus want to know if the scaring damage can be fixed? Thanks.
head number
the pr3-3 stamp
the damage
Old Mar 14, 2006 | 03:17 AM
methos713's Avatar
Default Re: need help identifying head... (methos713)
no one knows huh? Should of post this in the allmotor forum...they might have answers.
Old Mar 14, 2006 | 07:05 AM
methos713's Avatar
anyone?
Old Mar 14, 2006 | 07:19 AM
IntegraType-R's Avatar
b16 head..93...its really hard to tell that first year is 1993 i believe, but i have a gsr head, off a 94 jdm b18c, but it has 93 too on it, but the head came straight from honda, so i'm assuming its either a 93/94 b16 head..pr3=b16
Old Mar 14, 2006 | 08:15 AM
msmotorsports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 &raquo;</TD></TR><TR><TD CLASS="quote">here are some pictures...was told it was a 98 itr head. Plus want to know if the scaring damage can be fixed? Thanks.
head number
the pr3-3 stamp
the damage
Whats up with the journals? It looks like there are hairline cracks in them. Also they are very scuffed. Was the motor it was on previously oil starved?
Old Mar 14, 2006 | 09:00 AM
RPRacing's Avatar
-i cannot clearly read the first 2 digits in the first circle on the stamps.
-It is either a b16 or ITR head by the PR3 casting number
-Damage may be fixable with honing the caps.
-Jim Justice should have his hone by now. Call him up and send him the pics 301-624-1000
Old Mar 14, 2006 | 11:40 AM
methos713's Avatar
Default Re: (RPRacing)
thanks...and I don't know if there was stravation. All I was told was that the journals can be fixable and that it was a 98 itr head. As for that hairline crack...I didn't noticed it until I took the pix and posted it up...sucks But I'll go check the head to see if it is a crack. Does jim have h-t, cause I could just pm him.
Old Mar 14, 2006 | 11:41 AM
methos713's Avatar
Default Re: (methos713)
what else can I do to decide if this is a itr head? Could I check the valvesprings...since oem has the orange/blue color on them? Thanks.
Old Mar 14, 2006 | 02:29 PM
RPRacing's Avatar
-what are the first 2 numbers on the head?
-are the intake valves necked?
-is there any port work done at the bowls?
Old Mar 14, 2006 | 02:45 PM
lobudgetr's Avatar
Not a 99 head, is either 93 or 94, and most likely a B16A head, but if you have a good machine shop they can tell you for sure by the ports. I would also say that the damage is probably not fixable, but then again never tried, simply because I would not want to have my cams in that head spinning up to 10 grand, even after I had it fixed. Even honing them I would wonder what you would do to fix the gap that it would creatre around the cam, because if the cam moves in that journal even a little it will just keep destroying your cam seals.
Old Mar 14, 2006 | 02:54 PM
methos713's Avatar
Default Re: need help identifying head... (lobudgetr)
well, I'm going to take it to a machine shop and have them look at the damage, to see if its fixable. And what do you mean by "are the intake valves necked"?
Old Mar 14, 2006 | 04:41 PM
Runnerdown's Avatar
being that its a 93 head, I HIGHLY doubt it has anything to do with a type r. year of head manufacture is usually the model year of vehicle, or one year prior. I dont think honda would let the heads sit around for a few years and then use them.
Old Mar 14, 2006 | 06:24 PM
methos713's Avatar
Default Re: need help identifying head... (Runnerdown)
well, this head could be trash...I'm going to try going to some more shops to see what could be done about it.
Old Mar 14, 2006 | 08:46 PM
earl's Avatar
I would pretty much classify that head as junk. If you try to have the cam journals align honed, it will move the cams closer to the rocker/valves and probably throw off the valve geometry as well as the timing belt relationship.
ej93
Nov 11, 2010 12:02 PM
turbohatch96y7
Sep 11, 2009 08:05 AM
B18CRMiKE
Aug 21, 2005 01:52 PM
draggpa
Nov 2, 2004 03:08 PM
ragerized
Jun 4, 2004 09:47 AM
