getting ECU reading...im lost??
Old Mar 13, 2006 | 07:35 PM
integ69's Avatar
Default getting ECU reading...im lost??
hi guys i need help reading the ecu... i have a 94 integ ls and i took apart the panel under the glove box on the pass side and i saw the ECU. there is another thread here that shows how to jump 2 wires to read the ecu but thats for a civic. My integra ecu has no led light on it to see anything, im guessing it might be under neath its casing, i also see a plug that has 3 wires that isnt connectiong to anything! could that be the plug that i need to jump? because in that other thread it only has 2 wires.. if so which wires? Thanks guys i really appriciate it
Old Mar 13, 2006 | 07:39 PM
-Todd-'s Avatar
Default Re: getting ECU reading...im lost?? (integ69)
There's a wire that drops down around the glovebox area, the connector should be blue and it's not conencted to anything. This is what you "jump" to read the ecu code.
Old Mar 13, 2006 | 11:01 PM
integ69's Avatar
no the one i saw was white, i guess i should look deeper or something, Thanks...now for getting the blinker light going i have the tech manual for the car and it said that the D4 on the cluster would bling the code. Is this true or would i need to open the casing on the ECM for a led light
Old Mar 13, 2006 | 11:19 PM
PrinceAli132's Avatar
Default Re: (integ69)
How-to;
http://www.team-integra.net/se...ID=34
Ali
Old Mar 14, 2006 | 09:31 AM
integ69's Avatar
thanks alot prince
88_lsvtec_hatch
Sep 22, 2006 08:32 AM
dropd4door
Oct 5, 2004 06:20 PM
Eclpze97
Jun 22, 2004 06:33 AM
