Mar 13, 2006 | 09:15 PM
I have a stock intake and I want to get a mushroom-type filter from eBay. Does the 3" one fit? Also, do I take out the whole black resinator/box thing that is in there right now? Thank you in advance. By the way I have a 1999 GS.
Reply 0
Mar 13, 2006 | 09:18 PM
Re: Air Filter (count_chocula)
if you're going to get an ebay intake get one and then put a k&n filter on it. but yes you have to remove the entire intake its pretty simple took me 15 minutes.. maybe
Reply 0
Mar 13, 2006 | 09:24 PM
yea i would say a k&n filter would be ur best bet,than its not something cheap either
and its a easy install
Reply 0
Mar 13, 2006 | 10:28 PM
But the diameter of the stock intake is 3" correct? And if I got a mushroom filter would I have to take out the black resinator?
Reply 0
Mar 13, 2006 | 10:35 PM
I don't think you can connect an aftermarket filter to the stock intake tube... i guess you could try. but what is your obsession with the mushroom filter?? are you trying for CAI? or short ram? or what?
Reply 0
Mar 13, 2006 | 10:48 PM
I guess I am going for short ram but I don't have a lot of money, so I just wanted to upgrade the air filter until I save enough money for a better and CARB legal intake.
Reply 0
Mar 13, 2006 | 10:49 PM
I would just watch ebay I got AEM shortram for 95 bucks shipped
Reply 0
Mar 14, 2006 | 02:24 AM
Re: Air Filter (xDantex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDantex &raquo;</TD></TR><TR><TD CLASS="quote">if you're going to get an ebay intake get one and then put a k&n filter on it. but yes you have to remove the entire intake its pretty simple took me 15 minutes.. maybe</TD></TR></TABLE>
from what i hear, K&N filter have great air flow capacity, but their filtering is shitty .... i've been told that after market intakes don't really do the car anything ... OEM is best ...
correct me if i'm wrong?
Reply 0
Mar 14, 2006 | 02:33 AM
Re: Air Filter (lqdcourage)
the paper filter that is stock is ****. fram or whatever make they are. k&n have excellent flow and filter well as long as you take care of it and clean it and oil it. as far as aftermarket intakes adding power I've heard both ways. but I'm sure even if it does add power its not a lot. if its even noticable.
Reply 0
Mar 14, 2006 | 03:06 AM
Check out the sponsors section, they always have great deals. Just save up a little more and get a better intake. Something that you will feel.
Reply 0
Mar 14, 2006 | 05:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by count_chocula &raquo;</TD></TR><TR><TD CLASS="quote">I guess I am going for short ram but I don't have a lot of money, so I just wanted to upgrade the air filter until I save enough money for a better and CARB legal intake. </TD></TR></TABLE>
Well, AEM is ur best bet since it is CARB legal. If you want to just swap in a high flow air filter, go to Checker Auto parts and pick up a RU-2820 for only $30. There is a thread on how to cut it up and **** since i dont feel like typing how to do it for u. Search for DIY ice box, K&N, RU-2820.etc and you will find it.
Modified by RIP Indian Larry at 12:27 PM 3/14/2006
Reply 0
Mar 14, 2006 | 05:52 AM
Re: Air Filter (RIP Indian Larry)
you have to remove your stock air box, then open both sides of a soup can and stick it in your stock intake.... this is kinda like a adapter so the intake will work.... it sounds ghetto but hey its cheap and works, just make sure you dont get no chicken noodle soup in your intake manifold
Reply 0
Mar 14, 2006 | 07:31 AM
I say go k&n. I bought mine for two main reasons. Well three actually. First is that the stock filter even at oriley's or atozone cost 35 bucks. The k&n was close to 60, but after the first cleaning it paid for itself. Second, no parts stores around me ever have the stock paper filter in stock. 3rd i can use the stock box and pass emissinons and not look like i am trying to go fast or be cool. I would also remove the resnator. You dont have to but it does make it sound a bit louder and better in my oipinion.
Reply 0
Mar 14, 2006 | 09:31 AM
Re: Air Filter (pny1981)
definitely the KnN is worth it because not for the power "gains" everyone talks about but because you can use time after time. if you buy a stock air filter for like 20-25$, ull have to replace it sooner or later, with the knN, u can clean and it will be like a new filter everytime
Reply 0
Mar 14, 2006 | 09:37 AM
Re: Air Filter (RaceMyGhost)
if you are cheap them use pantyhose. I **** you not. Stretch panty hose across the intake hose. and zip tie it on. You can take your stock filter and start cutting away the paper portion. use the conection elbow and show the into the tube and try not to rip the panty hose.
Reply 0
Subscribe
