VSS problem Need help!
Old Mar 13, 2006 | 02:01 PM
Civicb1894's Avatar
Default VSS problem Need help!
Ok well i have a 94 civic dx, was auto and i converted to 5 speed and a gsr swap.
Now the problem im having is the speedo doesnt work anymore. I have changed the vss number of times. When i rev the motor the speed with jump and but wont move when the car is moving unless i go past 4,500 rpm and it will just jump all the was around to 0. Any help would be great, thanks.
Old Mar 13, 2006 | 02:06 PM
Kamin's Avatar
Default Re: VSS problem Need help! (Civicb1894)
you have a loose/bad connection
check the plug side of the TPS sometimes switching sensors back and forth the rubber gaskets can get stuck in the plug (harness side) and cause a bad connection.
Old Mar 13, 2006 | 02:13 PM
Russ713's Avatar
dAng!
Default Re: VSS problem Need help! (Kamin)
also check for bent prongs since a bad alignment when attaching plugs could easily cause them to get misaligned.
beat
Jun 7, 2010 01:33 PM
DrDvorkin
Sep 12, 2006 04:54 PM
veilsides2000
Sep 28, 2004 06:51 PM
Boosthead
24
Sep 10, 2004 08:04 AM
vtNaMeSe
Jun 21, 2003 06:55 AM
