burning a quart of oil a day!
Old Mar 13, 2006 | 08:13 AM
EF'n Sedan's Avatar
Default burning a quart of oil a day!
aight heres my question,the d15b2 in my beater burns a quart of oil a day and it
smokes like if i pull off from a stop sometimes. i was thinking the rings at first but
then i said maybe it could just be the valve stem seals?
any insight on what the prob could be??????
Old Mar 13, 2006 | 08:15 AM
si0385.'s Avatar
Default Re: burning a quart of oil a day! (EF'n SEDAN)
it could be alot of things
if the car is not smoking and using a quart a day have you checked for leaks?
Old Mar 13, 2006 | 08:16 AM
d16efsedan's Avatar
bump,my d15b2 and d16a6 does teh same thing.i tore the d15b2 down and it was nasty the rings was fried in it but it smoked like a raped banshee ,my d16a6 smokes a bit when i take off and if i rape it........bump for some answers
Old Mar 13, 2006 | 08:19 AM
Bravenrace's Avatar
Typically bad rings will cause smoke under acceleration and sometimes decelleration, and valve seals will cause smoke under high vacuum, like when decellerating.
Old Mar 13, 2006 | 10:32 AM
.Manny.'s Avatar
Touching My Member
compression test the bitch
Old Mar 13, 2006 | 10:59 AM
Mugencrxsir1's Avatar
Default Re: (90_EF_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bravenrace &raquo;</TD></TR><TR><TD CLASS="quote">Typically bad rings will cause smoke under acceleration and sometimes decelleration, and valve seals will cause smoke under high vacuum, like when decellerating. </TD></TR></TABLE>
Old Mar 13, 2006 | 06:26 PM
ck123's Avatar
bump i smoke too but i burn a quart every 1.5k miles
Old Mar 13, 2006 | 07:00 PM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: (ck123)
If you burn that much oil do you have a prayer to pass emissions (legally)?
p3
(and what technically is leaking, which vacs?) and check for 'regular' leaks too (gaskets, etc)
Old Mar 15, 2006 | 08:32 AM
EF'n Sedan's Avatar
Default Re: (phoenix_iii)
another thing that puzzles me is when i changed the oil there was obviously more
than 4qts of oil in the motor,because it started to overfill the 15qt. drain pan that i
used!!!
Old Mar 15, 2006 | 08:37 AM
LONESTARstateCIVIC's Avatar
Default Re: (EF'n SEDAN)
pull your spark plugs to see if there is any oil on the plugs. i have found valve stem seals leaking more than anything.
lilshady6796
May 24, 2009 04:07 PM
red teg
Oct 9, 2005 03:33 PM
IGOTpinkShards
May 28, 2004 10:48 PM
RvisionGSR
Mar 19, 2004 09:44 PM
someday
Nov 4, 2003 07:12 PM
