Whats the best throttle body to use for my mini me swap???
I think it's a B-series tb but I'm not sure 68mm maybe?? Will any one work or is some fabrication needed?? The swap is a d15/d16z6 head so what will bolt right up and connect right up to my set up?? I do have mpfi.........Thanks.
it will work all u have to do is dremel it. B series throttle bodies are great and easy mod for these motors.. if u have any questions just PM me..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screaming »</TD></TR><TR><TD CLASS="quote"> I think it's a B-series tb but I'm not sure 68mm maybe?? Will any one work or is some fabrication needed?? The swap is a d15/d16z6 head so what will bolt right up and connect right up to my set up?? I do have mpfi.........Thanks.</TD></TR></TABLE>
68 mm will be WAAAAAAAAAAAAAAY to big for your setup.
I was told this when i was choosing my TB for my supercharged CRX.
" what sort of power do you think its gonna put out? well, choose a TB from a motor similar to the power youre putting out "
you'll be fine with a 56-60 mm throttle body.
krysted9354
11
Nov 28, 2008 02:55 PM
Alchemist80
11
Sep 2, 2006 05:47 PM
5thgencivic
Dec 10, 2003 05:44 PM
