will type r throttle body bolt to gsr intake manifold
Old Mar 12, 2006 | 01:55 PM
boostedbluehatch's Avatar
Default will type r throttle body bolt to gsr intake manifold
will an integra type r throttle bolt to a gsr intake manifold or is the bolt spacing different ??????
Old Mar 12, 2006 | 05:49 PM
912's Avatar
912
Default Re: will type r throttle body bolt to gsr intake manifold (boostedbluehatch)
yes but you need the bracket of your gsr tb for the throttle cable
Old Mar 12, 2006 | 06:15 PM
IN VTEC's Avatar
Default Re: will type r throttle body bolt to gsr intake manifold (912)
Need to swap the pulley and spring too.
Old Mar 12, 2006 | 06:21 PM
Guzzie's Avatar
yes i swapped mine two weeks ago, main thing you need to do is cut the bracket that your throttle cable connects to from 2 bolt holes down to one, and then you will need to bend it slightly overso it lines up properly
Old Mar 13, 2006 | 10:27 AM
DownDC2's Avatar
yes perfect fit just need the gsr cable bracket...
masijdm
Jul 8, 2009 06:42 PM
rafaek9k24
May 28, 2009 04:05 PM
TurboIntegra
Jul 21, 2006 03:25 AM
tegsallgood
Dec 18, 2004 12:14 AM
905_S2K
Sep 12, 2001 05:09 PM
