Car doesn't want to start.
Old Mar 12, 2006 | 09:45 AM
huntarrr's Avatar
Default Car doesn't want to start.
I'll keep this brief... Hopefully i'll get some answers.
I swapped in a newer y7 block in my 98 civic about 3 weeks ago.. everything ran great with no CEL's until now. The car wont start on its own, but if I jump start it, it will run fine. There are some electrical problems im trying to get sorted out (my gauge cluster sometimes loses power and goes out). I already replaced the battery and it worked find for about a week, but now its back.
Sorry for the lack of information, but what could be wrong? Im thinking either:
a) Alternater
b) Starter
c) Just some messed up wiring.
Old Mar 12, 2006 | 11:26 AM
huntarrr's Avatar
Default Re: Car doesn't want to start. (vsm98civic)
bump
Old Mar 12, 2006 | 11:50 AM
ev13lf's Avatar
you need to check battery voltage, it should be roughly 12v with the key off, and @14v with the car running.
you need a multimeter, and if you don't have one i suggest getting one of the cheap ones they sell at radioshack or autozone - they work fine for occasional use.
if the voltage is under 14 with the vehicle running, you probably need an alternator.
good luck, hope i helped you out
Old Mar 12, 2006 | 01:10 PM
huntarrr's Avatar
Default Re: Car doesn't want to start. (ev13lf)
i took it up to auto zone, tried to check the alternator but the battery didn't even have enough juice to get through the test.
im sure its the alternator, but i dont know if its because of the wiring job or if it just plain went bad...
thanks for helping
EGHondalover88
31
Jan 18, 2010 03:26 PM
lawlss
15
Sep 14, 2009 10:23 PM
x1N5AN3x50ULJAHx
Oct 13, 2007 07:43 AM
MVP
Jan 10, 2006 09:58 PM
92CivicSIRhb
10
May 4, 2005 11:44 AM
