if u have a bad cylinder position sensor will your car start??
Old Mar 12, 2006 | 12:17 AM
h22_crx's Avatar
Default if u have a bad cylinder position sensor will your car start??
Old Mar 12, 2006 | 09:23 PM
Markb16a's Avatar
yeah mine is throwing that code and my car starts its just it makes the starter click a li but it starts .i dot know how to fix it thoguh
Old Mar 13, 2006 | 03:07 AM
killa rex's Avatar
Default Re: if u have a bad cylinder position sensor will your car start?? (h22_crx)
yea it will start...it's just a sensor in the dizzy..replace the dizzy and it should be fixed
Old Mar 13, 2006 | 08:03 AM
h22_crx's Avatar
Default Re: if u have a bad cylinder position sensor will your car start?? (xmunxjai648)
o
Old Mar 13, 2006 | 08:21 AM
jlicrx's Avatar
on the DOHC ZC, the CYLinder position sensor is on the exhaust camshaft - they almost never go bad - probably distributor wiring making it not start - did you get the distributor wired up?
Old Mar 13, 2006 | 04:42 PM
h22_crx's Avatar
Default Re: if u have a bad cylinder position sensor will your car start?? (jlicrx)
ok
Old Mar 13, 2006 | 06:17 PM
Tippyman's Avatar
My distributor bearing is bad so the shaft overheats. it eventually killed my sensor. Now i'm throwing a code 8, and I'm in limp mode. It still starts and drives, it's just really slow due to limp mode.
Old Mar 15, 2006 | 04:18 AM
h22_crx's Avatar
i check the ecu the light is on solid
Old Mar 28, 2006 | 12:30 PM
h22_crx's Avatar
any one
Old Mar 28, 2006 | 12:36 PM
Tippyman's Avatar
It doesn't blink? Just stays on continually?
Old Mar 30, 2006 | 06:17 AM
h22_crx's Avatar
Default Re: (Tippyman)
yeah the light is on soild
Old Mar 30, 2006 | 06:26 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (h22_crx)
a solid check engine light is a bad ecu code.
Old Apr 2, 2006 | 09:12 PM
h22_crx's Avatar
Default Re: (sanimalp)
i put in another still no luck
Old Apr 3, 2006 | 11:17 AM
h22_crx's Avatar
i check the ecu the is good. i guess it could be a bad ground
Old Apr 4, 2006 | 04:46 AM
h22_crx's Avatar
its was a bad ground
Old Apr 4, 2006 | 07:04 AM
janz3n's Avatar
hey which ground was it?? cuz i changed my dizzy and i still get that code after a mpfi swap.
Old Apr 17, 2006 | 06:02 PM
Del_Sol_s's Avatar
i have a 94 integra ls, its got a 97 ls motor in it and is throwing cel code 9, cylinder position sensor. where is the sensor located on this car?
lindylex
12
Apr 21, 2015 11:46 PM
Syke909
Nov 26, 2013 03:14 AM
Milby90ls
Sep 10, 2011 09:13 AM
quik89
Nov 30, 2003 06:43 PM
TEGPOWER44
Jan 13, 2003 04:00 PM
