bb4 Side Marker Help (searched)
Old Mar 11, 2006 | 10:40 PM
LUDER INTRUDER's Avatar
Default bb4 Side Marker Help (searched)*fourth generation Prelude*
Hey guys, I have a fourth gen prelude. I just got some side JDM side markers off of ebay and I was just wondering what are the exact mesurements on the fender where its supposed to be placed. I searched about it and I couldn't find anything about it. If possible can someone direct me to a link where maybe it can show me the "how to" to install them. Thanks.
Modified by LUDER INTRUDER at 10:40 PM 3/12/2006
Old Mar 11, 2006 | 10:49 PM
camil212's Avatar
Default Re: bb4 Side Marker Help (LUDER INTRUDER)
good question cause I'm doing the same soon, there was a thread like these a while ago and someone posted a template, I was so lazy to write the measurements down . I hope that person post it again
Old Mar 12, 2006 | 05:41 AM
iCe_2x's Avatar
Use your better judgement as to what looks good, and don't put them too high.
Old Mar 12, 2006 | 10:08 AM
Slatelude's Avatar
Default Re: (iCe_2x)
search a little more....should have everything you need....and more...
https://honda-tech.com/zerothread?id=1516265
K
Old Mar 12, 2006 | 10:11 AM
OEM_ASSASSIN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">OK, I took some first measurements...
Pic is very sketchy BTW
Old Mar 12, 2006 | 11:12 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (OEM_ASSASSIN)
Go to radio shack and buy some "Metal nibblers" Drill a hole into the fender (drill hole in the center) and then use the nibbler to start cutting away...It takes a little longer to do because you arent using a drimrel but it is easier and more accurate!
Old Mar 12, 2006 | 11:54 AM
RA61825's Avatar
dont be wack man just buy some real jdm fenders, ohh and the actual stanley sidemarkers are interchangable with the ek9 ones fyi.
Old Mar 12, 2006 | 02:57 PM
05member y0's Avatar
how is installing sidemarkers wack...???
and why bother buying jdm fenders, cause the only difference is the sidemarker.
sorry your post was dumb
Old Mar 12, 2006 | 09:34 PM
Is that template for a integra? or a Prelude? Because I followed the link and it sent me to this template. Or are they located on the same exact place?
http://pentaq.w.interia.pl/sidemarkers.jpg
http://www.we-todd-did-racing....D.jpg
I have my JDM sidemarkers wired to my front (inner) turn signals so that they only turn on when i signal.
Modified by LUDER INTRUDER at 11:30 PM 3/12/2006
Old Mar 12, 2006 | 10:28 PM
Jos3ph's Avatar
Default Re: (LUDER INTRUDER)
I didn't bother with that diagram so i used the measurements from these pictures from a real JDM fender to install my sidemarkers.
Old Mar 12, 2006 | 10:31 PM
Default Re: (Jos3ph)
Oh ok, that clears it up. I was kinda confused for a minute there but thanks.
jagstanger27
Apr 12, 2012 01:10 PM
OEMswagger
Honda CR-V & Element
23
Oct 12, 2011 06:16 PM
hondajav06
Aug 31, 2006 05:55 PM
Aznracerboy54
Jun 24, 2005 03:58 AM
el_Presidente
May 2, 2003 12:04 PM
