How do i time My D16??..
Old Mar 11, 2006 | 09:49 PM
D_CRX_Si's Avatar
Default How do i time My D16??..
Im so close to getting it running but after reinstalling both Timing belt and water pump, i think i might have turned the crank a bit..Now when i crank it is not have a familiar crank..it sounds different...How do i go about timing it right??
Old Mar 11, 2006 | 11:51 PM
Tad's Avatar
Tad
you need a honda service manual to set your timing correctly.
or at the very least a haynes/chilton manual that u can get at local autoparts stores(those do not have nearly as much info as the real deal helms manual though).
they can tell u how to set ur cam/crank timing.
you'll also need a timing light for ignition timing.
Old Mar 11, 2006 | 11:58 PM
EnzoSpeed's Avatar
Default Re: How do i time My D16??.. (D_CRX_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D_CRX_Si &raquo;</TD></TR><TR><TD CLASS="quote">Im so close to getting it running but after reinstalling both Timing belt and water pump, i think i might have turned the crank a bit..Now when i crank it is not have a familiar crank..it sounds different...How do i go about timing it right??</TD></TR></TABLE>
If the crank moved, why didn't you just move it back to TDC? It's not like there's some kind of secret here.
1. Set #1 piston to TDC
2. Make sure the cam gear timing marks are parallel to the head
3. Install belt.
Old Mar 12, 2006 | 01:49 PM
D_CRX_Si's Avatar
Default Re: How do i time My D16??.. (EnzoSpeed)
I dont have any marks how the Chiltons says(white Mark) to set the crank to TDC...I know the cam timing is correct upbut how else can i tell if im settin it to TDC
Old Mar 12, 2006 | 04:23 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D_CRX_Si &raquo;</TD></TR><TR><TD CLASS="quote">I dont have any marks how the Chiltons says(white Mark) to set the crank to TDC...I know the cam timing is correct upbut how else can i tell if im settin it to TDC</TD></TR></TABLE>
There have to be marks on the crank pulley. Even aftermarket pullies have the marks.
There should be three close together, then one spaced farther apart. Like this:
The mark by itself (on the right) is the TDC mark.
Old Mar 12, 2006 | 04:25 PM
Tad's Avatar
Tad
yeah, often times the white or red in the marks wears off with time and ur just left with grooves.
look at the positioning of the grooves not the color
Old Mar 12, 2006 | 06:31 PM
D_CRX_Si's Avatar
Ok i got the car running starts great, but the response is very bad...Does not revv up like it use to......Took it for a test ride and its alot slower when i get on it..Any suggestions.
Old Mar 12, 2006 | 06:58 PM
Tad's Avatar
Tad
ur cam timing could still be off by a tooth or two
triple check ur cam/crank timing and ignition timing.
Smash03
Apr 25, 2010 04:13 PM
dleccord
Jan 2, 2010 06:07 AM
marecco
Sep 7, 2007 01:12 PM
JediKGB
Dec 4, 2005 02:29 PM
Type-GS-R-Turbo
Dec 31, 2004 05:43 AM
