h22 eg hatch vtec has a mind of its own
Old Mar 11, 2006 | 08:33 PM
beaneg6's Avatar
Default h22 eg hatch vtec has a mind of its own
i have a h22 eg hatch and my vtec has a mind of its own, it works when it wants, sometimes it will only crack in first gear then stop working, if i turn off my car and turn it back on it works fine again but only for one gear, i am throwing top dead center check engine code, and o2 can someone help me out
Old Mar 11, 2006 | 08:45 PM
T
Default Re: h22 eg hatch vtec has a mind of its own (beaneg6)
i dont know im just think maybe possibly out of the blue i know but just maybe it might have something to do with the codes your throwing you think about that?? Go adjust your distributor with your cam gears until it is TDC and check your crankshaft pulley that just maybe might help and im pretty sure replacing your o2 might help some too if not in the VTEC area just maybe the gas mileage area. Cmon now dude think if your throwing codes fix em and then if VTEC's not working than you have a legitimate issue.
Old Mar 12, 2006 | 12:43 PM
beaneg6's Avatar
Default Re: h22 eg hatch vtec has a mind of its own (H22Hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Hatchie &raquo;</TD></TR><TR><TD CLASS="quote">i dont know im just think maybe possibly out of the blue i know but just maybe it might have something to do with the codes your throwing you think about that?? Go adjust your distributor with your cam gears until it is TDC and check your crankshaft pulley that just maybe might help and im pretty sure replacing your o2 might help some too if not in the VTEC area just maybe the gas mileage area. Cmon now dude think if your throwing codes fix em and then if VTEC's not working than you have a legitimate issue.</TD></TR></TABLE> if I could fix it I wouldn't be posting on here thanks a lot for the help ***
Old Mar 12, 2006 | 02:28 PM
VTECisSeXY's Avatar
*insert here*
how are you sure vtec isnt working? i have a h22 ek and I can barely hear vtec kick in.
Old Mar 12, 2006 | 02:35 PM
beaneg6's Avatar
Default Re: h22 eg hatch vtec has a mind of its own (VTECisSeXY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECisSeXY &raquo;</TD></TR><TR><TD CLASS="quote">how are you sure vtec isnt working? i have a h22 ek and I can barely hear vtec kick in.</TD></TR></TABLE>
i am positive that vtec is not kicking in because i have headers intake and exhaust with 2 1/2 piping all the way back and i can hear when vtec engages
Old Mar 12, 2006 | 03:01 PM
vsm_EJ6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 &raquo;</TD></TR><TR><TD CLASS="quote">
i am positive that vtec is not kicking in because i have headers intake and exhaust with 2 1/2 piping all the way back and i can hear when vtec engages</TD></TR></TABLE>
headers? sweet.. how'd you hook up more than one? Do you have a DIY post?
Old Mar 12, 2006 | 06:45 PM
beaneg6's Avatar
Default Re: h22 eg hatch vtec has a mind of its own (vsm_EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm_EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">
headers? sweet.. how'd you hook up more than one? Do you have a DIY post? </TD></TR></TABLE>
ok **** head i have a header thanks for the fcukin help
Old Mar 12, 2006 | 07:18 PM
vsm_EJ6's Avatar
Sorry..
Old Mar 12, 2006 | 07:24 PM
beaneg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm_EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">Sorry.. </TD></TR></TABLE>
sure
Old Mar 12, 2006 | 07:33 PM
92-LS-Civic's Avatar
cant offer much help in this area, so this is a free bump. If you havent looked up how to fix that code you are throwing i would suggest that. Do the adjustments and everything. SOrry i cant be any help.
Old Mar 12, 2006 | 09:53 PM
beaneg6's Avatar
Default Re: h22 eg hatch vtec has a mind of its own (92-LS-Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92-LS-Civic &raquo;</TD></TR><TR><TD CLASS="quote">cant offer much help in this area, so this is a free bump. If you havent looked up how to fix that code you are throwing i would suggest that. Do the adjustments and everything. SOrry i cant be any help.</TD></TR></TABLE>
thanks!!
Old Mar 13, 2006 | 07:35 PM
i dont know if anyone said where that TDC sensor is, but if i remember right that is in your distributor. My friend had a SI civic and that code came on. he had to replace his whole distributor, because you cant just buy that sensor. COuld be wrong, but that is what fixed his car. As for the O2 sensor, replace it, or try checking the connection. NOt sure and not 100% sure if im right anyways. good luck
Old Mar 13, 2006 | 09:37 PM
beatsperdream's Avatar
hah crazy
Old Mar 13, 2006 | 10:16 PM
beaneg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92-LS-Civic &raquo;</TD></TR><TR><TD CLASS="quote">i dont know if anyone said where that TDC sensor is, but if i remember right that is in your distributor. My friend had a SI civic and that code came on. he had to replace his whole distributor, because you cant just buy that sensor. COuld be wrong, but that is what fixed his car. As for the O2 sensor, replace it, or try checking the connection. NOt sure and not 100% sure if im right anyways. good luck</TD></TR></TABLE>
im not too sure thats why i posted on here for help but so far your the closest person to helping me...
Old Mar 14, 2006 | 11:30 PM
beaneg6's Avatar
help
Old Mar 15, 2006 | 03:34 AM
djsire's Avatar
lmao fix your car. its not in good runnning order. you konw what the problem is. so just fix it. o2 sesnsor get a new one. and check you wires. same with the dizzy.
viola your done
Old Mar 15, 2006 | 03:47 AM
Chillinit's Avatar
check for oil leaks oil leaks around the vtec soleniod.
The Destroyer
Apr 8, 2007 07:18 PM
Hatchorama
May 1, 2006 11:31 AM
beaneg6
Dec 23, 2005 04:17 PM
spooned out
Jun 16, 2004 07:44 AM
EK_logkomlki
Jun 9, 2003 06:49 AM
