stock p28 on b16
Old Mar 11, 2006 | 05:51 PM
erasable180's Avatar
Default stock p28 on b16
i'm running a stock p28 on my b16 right now, how much am i missing out on not having it chipped? i would imagine the fuel map and timing curve for the sohc is different from the dohc. not to mention vtec crossover and rev limiter. i have all the bolt ons and i'm wondering if its a waste of time with a stock p28.
Old Mar 11, 2006 | 06:06 PM
B.'s Avatar
B.
400 HP Club
Default Re: stock p28 on b16 (erasable180)
you're missing out on alot...... trust me get it chipped
Old Mar 11, 2006 | 06:36 PM
VILLIAN's Avatar
From: The world, chico, and everything in it., NV, USA
i had a stock p28 in my 94 b16a3 del sol before i got a chipped p28 in there and it was night and day. worth it!
Old Mar 11, 2006 | 07:04 PM
how much difference is there between a p28 and a b16 ecu?
Old Mar 11, 2006 | 07:05 PM
SVOboy's Avatar
Not enough to really hurt the engine, but enough for it to suck,
Send a pm to drdisco69 about getting it chipped.
Old Mar 11, 2006 | 07:12 PM
no wonder i've been hating my car...
Old Mar 11, 2006 | 07:14 PM
dreww..'s Avatar
damn, definitely get that chipped to b16 specs bro, its probably running terrible lol.
Old Mar 11, 2006 | 07:19 PM
Tatakai's Avatar
Default Re: (dreww..)
i had about a 1 second difference in 1/4 times with a p28 ecu vs a p72 ecu for my GSR-EG hatch
makes a difference, especially since your missing out on your top HP with an earlier redline. first time i ran down the track with the p72 i still shifted at about 6.5k.. just got a little faster 1/4 time. then i remembered to shift at 8k... oooweee that was a .6 improvement right there
Old Mar 11, 2006 | 07:31 PM
my one friend has been telling me for almost a year to get a chip, i guess he knew what he was talking about. i'm pretty anxious to get one now. what vtec crossovers and rev limiters do you guys run or suggest for my setup. my bolt ons are in my sig.
Old Mar 11, 2006 | 07:35 PM
Tatakai's Avatar
Default Re: (erasable180)
the stock b16 settings should be fine.. maybe have it tuned for a more aggressive fuel map and timing. your vtec x-over and redline should be fine. you could probably bump the redline up to 8k, providing you still have power over it.
i know someone with an LS who ran a p72 for a while, and still shifted at 6.5, because LS's just don't make power over that on their cams
Old Mar 11, 2006 | 07:54 PM
2000EM1's Avatar
Does anyone have stock setups for a B16a. I have the stock a2 in my EM1, and I have a P28 that I just need to chip... I'd like to burn it to stock settings for now and switch it out.
Old Mar 11, 2006 | 08:57 PM
SVOboy's Avatar
http://www.pgmfi.org has stock codes for most stuff in the ecu definition codes section of the library.
TheRobotSpy
Oct 11, 2009 08:02 PM
EJ SIR
14
Feb 19, 2009 01:55 PM
ivan93egreppin210
Dec 12, 2008 05:51 PM
bullock
Aug 19, 2004 08:14 AM
TyPe_R_GuY
Jul 11, 2004 02:47 PM
