how much as parts car?
how much do you think that i can get if i sold my car as a whole parts car.(whole car as parts car) i'd part it out but its gonna be too much work to pull the motor out and stuff when i have no tools to do it.
the run down
clean title
h22a1 93 prelude. 128k miles.
motor starts with no problems (reinforcent is pushed in.. bracket that holds radiator is broken, but nothin is leaking)
front reinforcement is bent in like crazy
driver side fender is crushed in from door opening up
driver quater panel was pushed in, pulled out and bondo'ed
interior is complete.
tires on rims are only like a month old b4 i crashed it
long story short:
how much can i sell as entire parts car as-is? or how much i should ask for if i were to list it somewhere?
dude i know you dont want to put any money into it...
but that is a SERIOUSLY EASY FIX. the only damaged structural part is the radiator support. your rails and everything else are straight. i'd fix it...
its not an easy/cheap fix after he replaces the front bumper support, hood, headlights, probably radiator along with the radiator support (which will have to be welded in place) grille (vents), front bumper, and paint and then align everything and then...
Easy/cheap fix if you know how to go about fixing it.....front bumper $80, junkyard/ebay headlights, junkyard/ebay radiator support,....run around primed....until you can get the $ to get it painted...........but if you want to sale......who am i to say different.......just my 2 pennies
its easy if u have the time and the money and your able to search for the parts easy. me, i dont have the time anymore for this car. ive put way too much money into it. its time for a new car.. possibly a 5th gen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThE PiMpiN Co »</TD></TR><TR><TD CLASS="quote">its not an easy/cheap fix after he replaces the front bumper support, hood, headlights, probably radiator along with the radiator support (which will have to be welded in place) grille (vents), front bumper, and paint and then align everything and then...</TD></TR></TABLE>
to me its an easy fix if it doesnt need a pull. everything on that car is straight as an arrow exc. for the rad support. doesnt even look like the condenser or rad were touched. all you have to do are drill out some spot welds...then weld in the new one
i bet you could fix that car with about $200 worth of junkyard parts
Depends on how much you want for it. Since you don't have the time to fix it, you probably dont have the time to part it out, although that would get you more money it will also take more time and work. I suggest posting it on eBay for what you want, and let the bidding take it from there...
sloturbohatch
Sep 8, 2012 10:02 PM
volkdlr
40
Apr 13, 2005 09:32 AM
