92 Accord Coolant Bleed bolt......Location?
Old Mar 11, 2006 | 05:54 AM
PIMPINSI's Avatar
Default 92 Accord Coolant Bleed bolt......Location?
Can somebody point me in the direction where i can find this BLEED bolt for the engine coolant... on my 92 Accord Ex...? What is the process to changing coolant when i find this bolt. I use to just fill the radiator below the fill neck and leave the cap off while the car was running, let the air bubbles escape, add as needed. When i didn't see anymore air bubbles i'd put the Rad. cap back on.....Is this wrong?
Old Mar 11, 2006 | 06:02 AM
YeuEmMaiMai's Avatar
Default Re: 92 Accord Coolant Bleed bolt......Location? (PIMPINSI)
it is right on top of the thermostat housing
Old Mar 11, 2006 | 06:16 AM
PIMPINSI's Avatar
Default Re: 92 Accord Coolant Bleed bolt......Location? (YeuEmMaiMai)
Is it number 13 in this drawing..?
http://www.hondaautomotivepart...+PUMP
What is the process......Do i need to pull it off completely while filling...?
Old Mar 11, 2006 | 06:18 AM
amckee's Avatar
Yes, open the bleed screw and fill the radiator with it open.
Old Mar 11, 2006 | 03:30 PM
dungeonKing's Avatar
no don't pull it out completely, just enough for air to escape, also when you are letting your car run and adding coolant as needed, make sure the car reaches operating temp. and the heater is on to allow full circulation
PearlJammzz
Feb 2, 2009 02:05 PM
sleepyone
Dec 9, 2008 04:34 PM
corince06
Jun 11, 2008 12:48 PM
mannyp4
Jul 9, 2007 09:21 AM
drumsy
Sep 12, 2002 07:14 AM
