Need your help on Jenvey ITB on 02 Civic w/ K20a2 swap. Pics inside.
Old Mar 10, 2006 | 09:02 PM
V-SPEC 1's Avatar
Default Need your help on Jenvey ITB on 02 Civic w/ K20a2 swap. Pics inside.
What's up guys, I have some problem and I need your help about k20 setup. hopefully you have some info and some advice to share. I have a Jenvey 52mm race version ITB and it's going into 2002 Civic Coupe w/ K20a2 swap. Here's my problem, the ITB don't have any place for Map sensor, Air intake temp. and no vacuum port whatsoever. Can you please tell me or show me some pics where I can place my Map, air intake temp.sensor and I think I need the one from B-series. where can I tap for vacuum? I also noticed that the throttle cable from the Civic don't open the ITB all the way to 100%. What cable did you use or maybe recommend for me to use? Let me see if I can show you some pics of the Jenvey:
Old Mar 11, 2006 | 04:32 PM
Tbone's Avatar
Default Re: Need your help on Jenvey ITB on 02 Civic w/ K20a2 swap. Pics inside. (V-SPEC 1)
Its a race part .. you need to be innovative if you want to play with race parts man.
I tapped each runner and put a bung for my vacuum lines, then made a vacuum can, i also got vacuum for all my other stuff from that can(brakes,map sensor)
You intake air sensor doesnt have a location , i made a bracket to hold mine with the probe stucking into the # 1 cylinder ait horn.
Old Mar 11, 2006 | 04:33 PM
Tbone's Avatar
Default Re: Need your help on Jenvey ITB on 02 Civic w/ K20a2 swap. Pics inside. (Tbone)
You can see my vac can in this pic behind the distributor down on the tranny.
Old Mar 11, 2006 | 07:52 PM
V-SPEC 1's Avatar
PM sent. thank you.
totsie7944
Feb 11, 2008 04:15 PM
V-SPEC 1
Mar 11, 2006 04:51 PM
ej2civic
10
Sep 20, 2005 04:58 AM
JDM_Risa
Aug 25, 2005 08:42 PM
b16powwer
12
Jul 21, 2002 03:01 PM
