Which Wiseco pistons for B18A/B?
Old Mar 10, 2006 | 02:17 PM
PhatBoy5015's Avatar
Default Which Wiseco pistons for B18A/B?
I am trying to decide between the K541M81 and the K542M81. I want my compression ratio to be somewhere between 8.4-8.9. I will be using a .074" Cometic head gasket. I tried to use a compression ratio calculator, but couldn't figure out what my piston-to-deck height was because when I entered what Wiseco said it would be, it came out to be a lot higher than what it was supposed to be. So which of these 2 should I get? Not trying to start a debate on which piston company is better, just want some opinions on these 2 sets. Thanks.
Old Mar 11, 2006 | 11:28 AM
ccivic's Avatar
Default Re: Which Wiseco pistons for B18A/B? (PhatBoy5015)
OEM gasket + K541M81.
Old Mar 11, 2006 | 02:26 PM
Default Re: Which Wiseco pistons for B18A/B? (ccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">OEM gasket + K541M81.</TD></TR></TABLE>
Well I already have the .074" gasket.
Old Mar 11, 2006 | 03:02 PM
ccivic's Avatar
Then go with the 542's if you're dead set on using that gasket. I would go with the 541's and OEM gasket. If you ever go LSVTEC, it will put your compression right around 9.0:1. With the 542s, you're probably going to be seeing high 9s with a VTEC head. I'd rather compensate with the piston, rather than a gasket.
Old Mar 12, 2006 | 11:27 AM
Well I am not going VTEC. Just LS turbo. I think I will get the 542. Thanks. Anyone else?
Blue94Accord
Oct 23, 2010 04:00 PM
raverx3m
Jul 15, 2010 08:21 PM
Speed Infliction
May 2, 2006 12:35 PM
turbotime
Nov 5, 2005 08:45 PM
