anybody change an axle
Old Mar 10, 2006 | 01:40 PM
devilpuppy's Avatar
Default anybody change an axle
okay, i'm gona be attempting to change both driveshafts(axle)
any tips? how-to's? pictures? etc.
Old Mar 10, 2006 | 04:41 PM
gianinline's Avatar
Default Re: anybody change an axle (devilpuppy)
Remove the wheels..... undo the "clip" on that main bolt so you can remove the whole rotor and caliper together... have someone holding that for you.... pull out the old axles... install the new one.... push it until you hear a little "click"... place everything back in... install wheels..... ....return old axles to get "that" refund....
Old Mar 10, 2006 | 05:36 PM
momstaxi's Avatar
one thing i noticed some people tend to do is remove the lower ball joint nut and actually remove the entire knuckle assembly...just leave the lower ball joint connected and swing the knuckle assembly out of the way...
Old Mar 10, 2006 | 05:45 PM
devilpuppy's Avatar
do you need to apply any grease anywhere or replaced any seals/washers etc.?
Old Mar 10, 2006 | 08:24 PM
Honda-Master's Avatar
go to http://www.ozaccord.com go to the articles, there is a step by step on how to written by deserthonda ..
ugandaHonda97
Dec 15, 2010 12:59 PM
ill fast
Dec 5, 2008 06:14 AM
sony224422
Jul 7, 2007 03:29 PM
O16581724 5 2 5
13
Sep 22, 2005 11:39 PM
serious
Mar 13, 2003 11:08 AM
