HELP!! car wont start after installing a/f guage
Old Mar 10, 2006 | 12:48 PM
silverboost's Avatar
Default HELP!! car wont start after installing a/f guage
i replaced my a/f guage and now my car turns over but wont start. After cranking for about 5 secs a cel will go on. When I turn the ignition off it will clear. Wat happened???????????
Old Mar 10, 2006 | 12:53 PM
skratchnsnift's Avatar
check fuel supply (fuel pump, lines, etc...)
Old Mar 10, 2006 | 12:56 PM
Default Re: (skratchnsnift)
its getting fuel, and 5 minutes before instaling the guage the car was fine
Old Mar 10, 2006 | 01:20 PM
Default Re: (silverboost)
my positive wire is hooked up to my ignition (empty fuse slot) thought this might help, any info would be aprreciated
Old Mar 10, 2006 | 03:45 PM
anyone????? i really need my car tonight
Old Mar 10, 2006 | 03:46 PM
schardbody's Avatar
disconnect the power supply and see if it will crank.
Old Mar 10, 2006 | 10:16 PM
disconnected the power supply to the guage and it will crank but not start
Old Mar 11, 2006 | 04:42 AM
anyone ??? im thinking thees a short sumwhere,, could this be it?
Old Mar 11, 2006 | 07:52 AM
SVOboy's Avatar
Have you tried putting it back like it was before you had the gauge in?
Old Mar 11, 2006 | 07:57 AM
yes i have and it still wont start, its getting fuel and al my other electrical things are fine, with the ignition on im hearing a quiet buzzing noise that seems to be coming from my alternator
Old Mar 11, 2006 | 08:40 AM
schardbody's Avatar
check all your fuses. sounds like you might have popped one, dont forget the ones under the hood.
Old Mar 11, 2006 | 01:27 PM
checked fuses they are all fine, i took out a spark plug wire and put in another plug and theres no spark when i tun it over
Old Mar 11, 2006 | 01:56 PM
RonMexic07's Avatar
what wires did you tap / alter when you installed the gauge?
Old Mar 11, 2006 | 03:41 PM
Default Re: (RonMexic07)
i have a seperate sensor in my downpipe for my guage, so 2 wires from the gueage connect to the sensor, the black one is grounded. My power sourc is form one of my empty fuse spots
Old Mar 12, 2006 | 12:40 PM
checked all my fuses and theyre all fine car stil wont start
Old Mar 13, 2006 | 10:15 AM
bump for needin to start my car still
JDM Freakk
Jun 21, 2011 05:36 PM
jaydm ferio
Dec 8, 2006 11:27 PM
gumbybum
Aug 10, 2003 04:57 PM
Audio28
Jul 3, 2003 05:33 PM
Unjockable
11
Aug 8, 2002 10:50 AM
