a/c problem
Old Mar 10, 2006 | 11:06 AM
tonezilla's Avatar
Default a/c problem
i installed my a/c back on after having it off for about 2-3 years . but after i finished my a/c install, there were a few problems .
1. the car constantly revs up by itself when the a/c is on . is there any way to fix this ?
2. when i turn on the a/c, it still smells like discharged freon . is there a way to get rid of this smell ?
3. when i make a turn, i hear a loud strange sound coming from the engine bay . my guess is maybe that it is the a/c alternator belt . it sounds as if it is slipping off of the compressor and alternator when i am making a turn . it doesn't make the sound when i am driving straight or when the a/c is off . i checked the belt, and there is no sign of it appearing to have slipped off of the compressor or alternator . the belt is new and it is tightened down . can anyone explain the strange sound ?
Old Mar 10, 2006 | 07:28 PM
YeuEmMaiMai's Avatar
Default Re: a/c problem (tonezilla)
install some leak dye
re-tension your a/c belt
it is possible your evap has a leak, see first suggection.
Old Mar 10, 2006 | 08:40 PM
tonezilla's Avatar
what is leak dye ?
Old Mar 11, 2006 | 06:01 AM
Default Re: (tonezilla)
it is usually red or greenish yellow in color (the visible ones) or an ultraviolet dye that they use a black light to see. It is added to the A/C system and will come out where the leak is.
Old Mar 11, 2006 | 04:20 PM
tonezilla's Avatar
and is this leak maybe the cause of my first two problems ?
Old Mar 11, 2006 | 04:27 PM
amckee's Avatar
The second problem, yes. The first problem, no. When you say it revs up, does it hold steady at a certain RPM or does it cycle up and down?
Old Mar 12, 2006 | 07:14 AM
tonezilla's Avatar
yeah, it constantly cycles up and down as soon as i turn on the a/c .
Old Mar 12, 2006 | 10:14 AM
amckee's Avatar
You probably need to clean your IACV. It is responsible for raising the idle during a/c usage. Does your engine normally idle at 750?
Old Mar 13, 2006 | 06:42 PM
tonezilla's Avatar
ok, but what about the stench problem ? someone told me that maybe a growth of mold might've formed in my vents from bacteria over a period of time while my a/c was off . they said that i could probably buy a can of disinfectant and spray it into the a/c intake . will this solve my stench problem ? if so, where would i need to spray the infectant into ?
Old Mar 14, 2006 | 03:31 AM
i'd check to see if your drain tube is clogged. If it is, unclog it and then use a bleach/water solution and spray the crap out of your duct system and the box that your evaporator is in uder the dash......
charmin
Jul 25, 2008 09:01 PM
Draggin99Si
Jan 20, 2006 04:48 AM
ek2k
Nov 26, 2004 02:09 PM
MrEg
Oct 13, 2003 04:48 PM
crxaddikt
Feb 28, 2003 03:40 PM
