Torque spec for header on Type R
Ok OK I am an idiot what are the specs to put my header back on. I have called toda themselves and they wont give it to me they said it factory specs for the car wich is what? Someone please help I wont just slap it on without the proper spec and procedure
after searching
The spec for the studs and bolts at the head is 23 ft. lbs. The should be tightened in sequence started at the center and alternating outward.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jspecjoe »</TD></TR><TR><TD CLASS="quote">well I tried to archive it but didnt use that term thanks, I used 24 from center out and everything is ducky now.</TD></TR></TABLE>
What did you search for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jspecjoe »</TD></TR><TR><TD CLASS="quote">everything is ducky now.</TD></TR></TABLE>
wtf?
wtf?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">The spec for the studs and bolts at the head is 23 ft. lbs. The should be tightened in sequence started at the center and alternating outward. </TD></TR></TABLE>
This reads almost exactly like something I wrote....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid »</TD></TR><TR><TD CLASS="quote">What did you search for?</TD></TR></TABLE>
