sol vti no sparks? HELP!
Old Mar 10, 2006 | 06:27 AM
legal r's Avatar
Default sol vti no sparks? HELP!
After 2 months i want to start my delsol vti, but it won’t start anymore,
There is no spark, I have replaced al lot of things but nothings works.
I replaced: sparkplugs, sparkwires, complete ignition, the ECU, i checked al the wiring but can’t find nothing wrong there. The engine has a good ground, and there is a 12V signal on the black/yellow wire.
But stil no sparks, what could this be?
Old Mar 10, 2006 | 06:33 AM
IHateJDM's Avatar
Default Re: sol vti no sparks? HELP! (legal r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legal r &raquo;</TD></TR><TR><TD CLASS="quote">
I replaced: sparkplugs, sparkwires, complete ignition, the ECU, i checked al the wiring but can’t find nothing wrong there. </TD></TR></TABLE>
what do you mean by complete ignition? the dizzy, the coil, the ignitor?
Old Mar 10, 2006 | 06:48 AM
legal r's Avatar
Yes the complete ignition
Old Mar 10, 2006 | 07:24 AM
imm0rt41's Avatar
Is the battery putting out a good charge? It doesn't look like you have changed that yet or at least charged it so I would give that a shot.
Old Mar 10, 2006 | 09:09 AM
legal r's Avatar
i have a almost new battery whit enough power
Old Mar 11, 2006 | 08:57 AM
ChristianM19's Avatar
coooooooooool
after 2 months you wanted to start your car again...Changed everything but it doesn't start. Plugs on the dizzy cap put in the wrong order? alternator? ignition coil went bad? bought the wrong dizzy? Since you bought the "complete" ignition...was it used? new? don't know? part number of the distributor?
U buy the wrong part and your car won't start unless you know which way the sparks are firing on the distributor...
Old Mar 11, 2006 | 09:15 AM
legal r's Avatar
the comlete igition comes from a runnig car from a friend, changed it, and my car stil dont start. plugs on the dizzy cap also in the right order.
only i have nothing done with te alternator, should there be a problem???
i can dissconect him, tomorrow i try that
mcnos
Aug 15, 2011 06:22 AM
RyanJC
Jan 5, 2010 06:46 PM
ion_four
Oct 27, 2002 06:25 PM
aNaRcHyiNmYeK
Apr 24, 2002 07:04 PM
