sol vti no sparks? HELP!
After 2 months i want to start my delsol vti, but it won’t start anymore,
There is no spark, I have replaced al lot of things but nothings works.
I replaced: sparkplugs, sparkwires, complete ignition, the ECU, i checked al the wiring but can’t find nothing wrong there. The engine has a good ground, and there is a 12V signal on the black/yellow wire.
But stil no sparks, what could this be?
Re: sol vti no sparks? HELP! (legal r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legal r »</TD></TR><TR><TD CLASS="quote">
I replaced: sparkplugs, sparkwires, complete ignition, the ECU, i checked al the wiring but can’t find nothing wrong there. </TD></TR></TABLE>
what do you mean by complete ignition? the dizzy, the coil, the ignitor?
coooooooooool
after 2 months you wanted to start your car again...Changed everything but it doesn't start. Plugs on the dizzy cap put in the wrong order? alternator? ignition coil went bad? bought the wrong dizzy? Since you bought the "complete" ignition...was it used? new? don't know? part number of the distributor?
U buy the wrong part and your car won't start unless you know which way the sparks are firing on the distributor...
the comlete igition comes from a runnig car from a friend, changed it, and my car stil dont start. plugs on the dizzy cap also in the right order.
only i have nothing done with te alternator, should there be a problem???
i can dissconect him, tomorrow i try that
