replacing valve train
Old Mar 9, 2006 | 05:43 PM
dkk119's Avatar
Default replacing valve train
i was tring to replace all the valve train on a b16 head my self and i was wondering for those that do this, what tools do you guys use? what style valve spring compressor and other tools
Old Mar 9, 2006 | 06:29 PM
Honda Sport's Avatar
if you're just replacing the valvetrain, they make a tool that doesn't require taking off the head. you can find it at shuck's, napa, or any automotive place. if you do that, you have to find a way to keep the valve from dropping into the cylinder. ie, air compressor or stuff the cyl with string.
Old Mar 10, 2006 | 06:22 AM
dkk119's Avatar
Default Re: (Honda Sport)
do you know what that tool is called? my head is already off.
Old Mar 10, 2006 | 06:54 AM
Ruben19's Avatar
if your head is off.
get yourself a 13/16 deep socket and open a hole in there.
you can use this socket with the spring compressor C-clamp.
i use this and it worked very well.
Old Mar 10, 2006 | 05:42 PM
Default Re: (Ruben19)
it's called a valve spring compressor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 &raquo;</TD></TR><TR><TD CLASS="quote">if your head is off.
i use this and it worked very well.</TD></TR></TABLE>
this works too. I had to do this just today on a GSR head cause the spring compressor wouldn't reach inside the head. I got out an O2 sensor socket(has a cutaway in the socket), compressed the spring with the valve spring comressor with the O2 socket, all worked out well.
Old Mar 11, 2006 | 04:19 PM
dkk119's Avatar
that's the problem i have. i cant get inside the hed. i was just trying to see if there was any other way to do that istead of the socket way. i've done that b4
Old Mar 11, 2006 | 05:39 PM
Ruben19's Avatar
i just bought a tool on ebay that can be use to remove the valve springs without taking the head off.
just type b18 valve spring compressor
i paid $55
it should be a very helpfull tool.
i will try it when my cams and valve springs get here.
Old Mar 11, 2006 | 09:26 PM
Garcia-Racing's Avatar
I use the SP tools. It works great. You can do a search on here to see pics of it.
Old Mar 12, 2006 | 03:16 PM
dkk119's Avatar
Default Re: (Garcia-Racing)
SP tools? i also looked at the tool on ebay, i guess all you'd have to do is tighten the spring? how hard would it be to compress the spring with a bolt?
Old Mar 12, 2006 | 05:45 PM
Default Re: replacing valve train (dkk119)
https://honda-tech.com/zerothread?id=1269823 here you go.
Old Mar 13, 2006 | 06:27 PM
dkk119's Avatar
Default Re: replacing valve train (Garcia-Racing)
thanks alot
i was wondering does anyone have expreience with this tool?http://www.harborfreight.com/cpi/cta...emnumber=92900
95gsr@530
Engine Machining & Assembly
Nov 23, 2015 05:42 AM
boostd92
Sep 12, 2008 05:40 PM
mycrx7
Sep 22, 2005 08:03 PM
ricearoni56
16
Jun 19, 2004 09:16 PM
Steve91
Sep 19, 2003 11:53 AM
