type r wire harness?
Old Mar 9, 2006 | 05:20 PM
musTerdh22eg's Avatar
Default type r wire harness?
my car wasnt running too well so i took it to a local shop. the wire harness that was in there was all chopped up, whoever did the swap did a shitty job so im gonna get the harness replaced. i bought the car with a type r ecu so the mechanic at the shop said to use a type r wire harness. should i go with that or get a b16 harness or does it not matter?
Old Mar 9, 2006 | 05:57 PM
pennies_hatchie's Avatar
Default Re: type r wire harness? (myb16civic)
well judging from your avartar, im guessing you have an ek, the type r wire harnes wont fit, its a 2 piece vs the 1 piece civic harness, so if it is an ek, then use your stock harness or ex/si one.
if its an eg, then yeah, use a type r, gsr, or ex/si one
Old Mar 9, 2006 | 06:00 PM
Default Re: type r wire harness? (pennies_hatchie)
yeah its an ek, i hope he didnt already order the type r harness
Old Mar 9, 2006 | 06:26 PM
BlueIntegraBoy's Avatar
Order a 96-98 EX harness
Old Mar 9, 2006 | 06:28 PM
Slopoke's Avatar
Default Re: type r wire harness? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Order a 96-98 EX harness</TD></TR></TABLE>
Yep.
Dont get the '99-'00 si harness, cause the obd2B engine harnesses are different than your obd2A.
CasperX
Mar 21, 2016 12:48 PM
Katman
Aug 12, 2007 04:57 AM
dc2dragster
Mar 13, 2003 11:45 PM
SiViK-R
Mar 23, 2002 07:55 PM
