Injector Resistor Box
Old Mar 9, 2006 | 02:25 PM
DA jeshy's Avatar
Default Injector Resistor Box
if i have a 93 integra and i am turboing it. if i install new Injectors do i need to install a injector resistor box ?
Old Mar 9, 2006 | 02:57 PM
LoseRPunKx182's Avatar
Default Re: Injector Resistor Box (DA jeshy)
peak and hold yes saturated no
Old Mar 9, 2006 | 04:40 PM
VTteg's Avatar
Default Re: Injector Resistor Box (LoseRPunKx182)
I predict that you will be doing a lot of research in the near future.............
^^^this guy's correct
Old Mar 9, 2006 | 05:59 PM
DA jeshy's Avatar
Default Re: Injector Resistor Box (VTteg)
yes i will be
thanks guys
Old Mar 9, 2006 | 06:02 PM
KeithsDAteg's Avatar
No you dont need to. You can, It is an option, but by no means do you have to.
The more simpler route to go, would be to install 10watt 10ohm resistiors.
Here is a link :
http://www.homemadeturbo.com/t...tors/
Old Mar 9, 2006 | 06:10 PM
DA jeshy's Avatar
Default Re: Injector Resistor Box (KeithsDAteg)
"Now alot of people are installing these DSM injectors (hold & peak) into their 5g Civics that are (saturated) style injector systems. You will have to install a factory Honda Injector resistor box, or you can do it this method. First you will need to cut open the stock wiring harness to get a closer look at all the wires."
Saturated Injectors:
1997-up Prelude VTEC
1992-95 Civic Si/EX
1996-00 Civic
<U>1992-00 Integra LS/GSR/ITR </U>
ok so i have a 93 LS so all i have to do is install the Saturated injectors and ill be good to go.
Old Mar 9, 2006 | 06:18 PM
Dude, You can pick up some DSM 450cc injectors on Ebay or H-T for less than $100 . Then just install 10watt 10ohm resistors to each black and yellow wires.
Just like the picture shows:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Homemadeturbo &raquo;</TD></TR><TR><TD CLASS="quote">On each injector you have a yellow/black wire. This is the power wire from the ECU. This voltage is constant and needs to be regulated, thus using a inline resistor. We have used 10watt 10ohm inline resistors from radio shack, they cost about 5 bucks for 4 of them. (packs of 2) Cut each wire (one at a time) strip the wire back and twist the wire around the resistor wire. I highly recommend using solder on this connection, as shown. Then tape up each resistor really good with some electrical tape. </TD></TR></TABLE>
Old Mar 9, 2006 | 06:21 PM
DA jeshy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeithsDAteg &raquo;</TD></TR><TR><TD CLASS="quote"> Then just install 10watt 10ohm resistors to each black and yellow wires.
i put the resistors on the yellow and black wires coming from the wiring harness right not to the injector plugs.
and if im a 93 LS can i use my stock Injector connectors Plugs?
sorry for all the questions
Modified by DA jeshy at 7:37 PM 3/9/2006
Old Mar 10, 2006 | 03:37 AM
VTteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeithsDAteg &raquo;</TD></TR><TR><TD CLASS="quote">Dude, You can pick up some DSM 450cc injectors on Ebay or H-T for less than $100 . Then just install 10watt 10ohm resistors to each black and yellow wires.
Damn, there has got to be a cleaner way to do that......................
Old Mar 10, 2006 | 12:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA jeshy &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by DA jeshy at 7:37 PM 3/9/2006</TD></TR></TABLE>
Yep!
Old Mar 10, 2006 | 01:13 PM
DA jeshy's Avatar
ty dude alot of help
japspecb7
Jul 23, 2008 10:20 AM
97turboteg
Apr 3, 2006 08:07 PM
adnoh
Jun 10, 2004 10:51 AM
turbocivic96
Jan 29, 2004 05:09 PM
B20-T
Jun 22, 2002 11:29 AM
