evo 560cc injectors
Old Jul 22, 2008 | 06:25 PM
japspecb7's Avatar
Default evo 560cc injectors
these are the injectors im going to run and i know i have to use a resistors box box. But i want to run the the 4 single resistors on each of the injector clips. click this link to see what im talking about: http://www.radioshack.com/prod...earch
has anyone ever used it? do yall think it will last a long time like a year or two?
Modified by japspecb7 at 7:32 PM 7/22/2008
Old Jul 22, 2008 | 07:52 PM
TehGhett0P1mp's Avatar
Default Re: evo 560cc injectors (japspecb7)
Why not just use the box? I dont see the point of using individual resisters..
Old Jul 22, 2008 | 10:50 PM
VTECth1s's Avatar
Default Re: evo 560cc injectors (TehGhett0P1mp)
It's faster to install with the individual resistors imo.
Using a resistor box is cleaner and gives it the stock appearance in the engine bay. It's a bit more wiring and time compared to the individ. resistors, like a 3-5 mins more. Either way, there both easy to install.
Old Jul 23, 2008 | 08:38 AM
japspecb7's Avatar
Default Re: evo 560cc injectors (VTECth1s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECth1s &raquo;</TD></TR><TR><TD CLASS="quote">It's faster to install with the individual resistors imo.
Using a resistor box is cleaner and gives it the stock appearance in the engine bay. It's a bit more wiring and time compared to the individ. resistors, like a 3-5 mins more. Either way, there both easy to install.</TD></TR></TABLE>
will the individual resistors work as same as the box?
Old Jul 23, 2008 | 09:08 AM
boostedcivicsir's Avatar
Mr. Badwrench
if you find the deadhead plug, solder in a plug from an obd0 single cam dpfi dizzy, you can plug it right into the resistor box, and when and if you need to go back to stock, unplug the box, and take the other end of the dizzy plug and make a shorting bar type connector.
i dont see how it is easier to put 4 individual resistors in over using the dead plug and a resistor box, but thats my o.o2.
Old Jul 23, 2008 | 09:30 AM
japspecb7's Avatar
Default Re: evo 560cc injectors (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">if you find the deadhead plug, solder in a plug from an obd0 single cam dpfi dizzy, you can plug it right into the resistor box, and when and if you need to go back to stock, unplug the box, and take the other end of the dizzy plug and make a shorting bar type connector.
i dont see how it is easier to put 4 individual resistors in over using the dead plug and a resistor box, but thats my o.o2.</TD></TR></TABLE>
Old Jul 23, 2008 | 09:37 AM
Mr. Badwrench
yes, i have never used them, i couldnt get the install as clean as i would have liked, plus they get hot, so dont wrap them with tape or hide them in a harness.
Old Jul 23, 2008 | 10:20 AM
japspecb7's Avatar
thanks
2ndchirp
Oct 26, 2008 05:09 PM
DA jeshy
Mar 10, 2006 01:13 PM
B18 CYA
Jun 24, 2004 06:44 PM
dc2pffsssttt
Apr 14, 2004 08:04 AM
turbocivic96
Jan 29, 2004 05:09 PM
