Need to install a fuel pump on a 90 integra LS
Old Mar 9, 2006 | 01:50 PM
darkfx's Avatar
Default Need to install a fuel pump on a 90 integra LS
Where can i find the directions? thanks
Old Mar 9, 2006 | 01:53 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: Need to install a fuel pump on a 90 integra LS (darkfx)
are you asking where it is located? If you know than its not hard at all, basically just take off the bolts and pull it up
Old Mar 9, 2006 | 02:05 PM
solareclipseauto's Avatar
Default Re: Need to install a fuel pump on a 90 integra LS (BOLO-FTW!!)
dont you have to drop the tank on that year
Old Mar 9, 2006 | 02:09 PM
Dforce's Avatar
That's what she said!
i'd like to know too.
Old Mar 9, 2006 | 02:10 PM
rkrone's Avatar
yes, you need to drop your tank!!!
ah, this sucks
there are two hangers for it, the bolts are at the back of the car, undo those, then the tank will come down, so have something supporting it, ease it down, btw, the wires from the top should be disconnected from under the rear seat first, there is also as conver over the fill tube on the drivers side, 3 or 4 bolts, once that is off, you can take all the tubes off the tank, then lower it until you see the top, the fuel pump is in the bottom back left of the tank (looking from behind the car) once the tank is down the pump is not hard to swap
Modified by rkrone at 6:50 PM 3/9/2006
Old Mar 9, 2006 | 02:20 PM
Guess whos bizzack
Default Re: Need to install a fuel pump on a 90 integra LS (rkrone)
woah i missed the year, ya sorry not as easy as I thought it would be, have fun I hope for your sake the bolts arent too rusty!!
Old Mar 9, 2006 | 02:33 PM
DA jeshy's Avatar
do i have to drop the tank on a 93 ls?
Old Mar 9, 2006 | 02:56 PM
LoseRPunKx182's Avatar
Default Re: Need to install a fuel pump on a 90 integra LS (DA jeshy)
2nd gen drops
Old Mar 9, 2006 | 05:26 PM
Default Re: Need to install a fuel pump on a 90 integra LS (LoseRPunKx182)
yup 90-93 you have to drop the tank
Old Mar 9, 2006 | 05:57 PM
DA jeshy's Avatar
Default Re: Need to install a fuel pump on a 90 integra LS (solareclipseauto)
Old Jul 13, 2015 | 04:50 AM
jim_me_87's Avatar
Hopefully this video will help some of you 2nd gen (1990-1993) owners with your fuel tank removal to access your fuel pump. I have a 90 LS. I kept reading that everyone wanted a step by step process but I couldn't find one myself. Check out the video I did after removing my gas tank.
And use some rust penetration spray to loosen all connections!!
tobytigger
Jul 22, 2017 05:02 PM
turboZChatch
Sep 25, 2003 04:03 AM
B20LS-T
Aug 16, 2003 10:56 PM
rustycivic
Mar 25, 2003 06:32 PM
Vtecless212
Mar 7, 2003 02:03 PM
