MAD vibration problems again on GSR
my car has been vibrating everytime i gas it especially at midrange. my steering wheel feels really loose too, like unbalance. when i go fast i feel unsafe. i tried new axles and tires. vibrationg still occurs, im thinking motor mounts or unbalalanced tires? someone help me out please.
Tie Rod ends? upper and lower ball joints? could still be the axles. are they reman?
alignment maybe. Rims could be bent. Try balancing the rims and tires.
Yeah, I had a 2001 Jeep Grand Cherokee with tons of vibrating problems. You should probably get your rotors recut/buy new ones, and then get an alignment along with getting your tires balanced. Don't do anything really expensive till you find out the real problem
make sure that your tires are balanced properly
get your car aligned
make sure that the heat shield is not rattling
new pads/rotors will do wonders
(3g integras are notorious for a rattle in the steering wheel during braking after about 20k miles)
