Poppin from the front end?
Old Mar 9, 2006 | 07:40 AM
stockcivic103's Avatar
Default Poppin from the front end?
Hey guys, i have a 92 civic cx hatch, and i replaced the front struts and put some coilovers on it, and when i take off, while turning, it makes a pop, im wanting to think that its the fron LCA bushing but im not sure, can someone confirm my judgment?
Old Mar 9, 2006 | 08:26 AM
94hatchling's Avatar
is it just one pop? like when changing the direction of the tires? or going from reverse to forward?
anyway... sounds like a balljoint to me from what you have said. check your balljoints, or take it to a shop to have them correctly checked. mine does the same thing, and its an outer tie rod that is making the noise.
good luck
Old Mar 9, 2006 | 08:31 AM
pdiggitydogg's Avatar
I agree, sounds like a balljoint (do not let these go...)
Old Mar 10, 2006 | 04:48 AM
Default Re: Poppin from the front end? (stockcivic103)
Yes, its just one pop, like when im turning and accelerating, it'll pop, or when i accelerate hard from a stop light.... it just randomly pops
How do i check the ball joints?
Old Mar 10, 2006 | 07:20 AM
dpkelly's Avatar
Reach above the front tire and pull the steering knuckle back and forth (if you can on a lowered car). I had the same issue and it's fixed by replacing the upper control arm that has the upper ball joint. If it moves and makes a sound, then bingo that's it.
Modified by dpkelly at 11:40 AM 3/10/2006
Old Mar 10, 2006 | 07:42 AM
mike1114's Avatar
Default Re: Poppin from the front end? (dpkelly)
It is cause the spring on the coilovers is not under any stress cause its too short.
It pops cause it is not sitting right on the tophat, when you go, it puts some strees on the spring so it "pops" into where it is supposed to go.
I had this problem forever before I figured it out.
Old Mar 10, 2006 | 07:48 AM
unbolt the ball joint and check for excessive play - it should be somewhat resistant to movement
codizz88
Jul 10, 2016 05:48 AM
1badcrx
May 13, 2011 09:05 PM
svtford4x4
Mar 14, 2011 03:12 AM
allmotorpackage
Suspension & Brakes
Oct 24, 2007 03:09 PM
:David:
Feb 5, 2006 06:18 PM
