Ahh, having a fresh rear motor mount put in is the greatest
Old Mar 9, 2006 | 06:23 AM
bluskye's Avatar
Default Ahh, having a fresh rear motor mount put in is the greatest
1994 honda accord ex 100k miles.
I swapped out my cracked front motor mount couple months ago myself. It helped, but still a good amount of engine moving on deccerleration or fast clutch in. I had the timing belt done (all belts/seals/pump etc) and asked for the motor mount installtion. All OEM. MAN, what a freaking difference. No engine rocking when coasting at 2k rpm in 3rd or 2nd gear..... Now i want to do the side mounts for the hell of it. There is a slight movement still, but nothing severe like before and Im sure the side mounts can use a swap after 12 yrs. The engine jack-hammering when the clutch is cold and getting off 1st gear is gone too. Good stuff, the car rides extremely well now for a 12 yr old car. Hopefully it will last another 50k miles without major issues.
Old Mar 9, 2006 | 06:25 AM
YeuEmMaiMai's Avatar
Default Re: Ahh, having a fresh rear motor mount put in is the greatest (bluskye)
i got an auto 94 accord nearing 150K everything is still good
Old Mar 9, 2006 | 09:33 PM
FallenAngelHIM's Avatar
do you think Honda's will survive a nuclear holocaust too?
Old Mar 9, 2006 | 10:35 PM
Dmc1's Avatar
I just changed the front and rear mounts on my 90 ex auto.It does make a big differance.
Old Mar 10, 2006 | 07:55 AM
P_Adams's Avatar
You're lucky you never went thru a broken rear mount on '89 and earlier Accords (auto). The engine shook so bad at idle that things actually started falling off the car.
There's a lot to be said for a smooth idle, and a well secured engine; but it can also be said it's a pretty interesting effect under heavy vibration to look over and think you're seeing your wife with more than two mammalian protuberances.
You just don't know where to start, man.
P
Old Mar 10, 2006 | 08:31 AM
bluskye's Avatar
Default Re: Ahh, having a fresh rear motor mount put in is the greatest (P_Adams)
Does the driver's side mount hold the engine while engaging clutch and cause some wheel hop when worn out in addition to hard shifting into first when idle? What are the symptons of driver's side failure vs passenger side (tranny) mount failure?
Old Mar 10, 2006 | 09:11 AM
flight50's Avatar
I believe wheel hop, as far as mounts go, are due to the main support mounts for movement which are the front and rear mounts.
Old Mar 10, 2006 | 04:46 PM
gianinline's Avatar
Default Re: (FallenAngelHIM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FallenAngelHIM &raquo;</TD></TR><TR><TD CLASS="quote">do you think Honda's will survive a nuclear holocaust too?</TD></TR></TABLE>
The answer is yes, Hondas last for ever!!!
My motor mounts have small cracks... I think all of them.... but I don't feel anything wrong with them yet... the mechanic told me they are still good for now when we installed my new clutch.
How much is all 4 motor mounts for a F22B1 for 97 accord with 5sp?? ...I was just wondering...?
Old Mar 10, 2006 | 07:01 PM
bluskye's Avatar
You can do price look up:
http://www.hondaautomotiveparts.com/
As for labor, ask your mechanic. I was charged 1hr for the rear which is the hardest of them all. The other three I can do myself.
Old Mar 10, 2006 | 08:11 PM
philadd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">You're lucky you never went thru a broken rear mount on '89 and earlier Accords (auto). The engine shook so bad at idle that things actually started falling off the car.</TD></TR></TABLE>
Oh, man... I went through that with my '88 auto. NOT fun.
Old Mar 10, 2006 | 08:16 PM
P_Adams's Avatar
Default Re: Ahh, having a fresh rear motor mount put in is the greatest (philadd)
I know, my wife's '89 LXi got so bad that the front Bumper Cover started breaking loose and the hood prop rod fell to the ground one day! Frak, the &^*% thing vibrated almost as bad as an AMC Harley.
For grins, on day I took tape measure in hand and measured the range the steering wheel was shaking. I swear it was at least 3/4 of an inch, if not more.
P
Old Mar 10, 2006 | 08:25 PM
gaydm.accord's Avatar
you ever consider mount inserts? i just installed my front today... i love it. very minimal wheel hop... cant wait to get my rear one in.
Old Mar 10, 2006 | 11:40 PM
philadd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">I know, my wife's '89 LXi got so bad that the front Bumper Cover started breaking loose and the hood prop rod fell to the ground one day! Frak, the &^*% thing vibrated almost as bad as an AMC Harley.
P </TD></TR></TABLE>
"Frak"? Been watching Battlestar Galatica?
My '88's bumper shook enough that the fog lights broke off...
Old Mar 11, 2006 | 05:09 AM
P_Adams's Avatar
Geez, and I thought I'd get it for the AMC Harley comment (LOL)
Hey, It's either BSG (arguably the best) or the 240th rerun of Law & Disorder!
P
Old Mar 11, 2006 | 03:38 PM
dungeonKing's Avatar
yes i need to do the same to mine, it is hard for me to spend money on my daily driver but i am sure i will appreciate it once its done
Old Mar 11, 2006 | 04:04 PM
P_Adams's Avatar
Default Re: (stiffmeister)
It's a night-n-day kinda thing. Believe me, putting money into an 16 year old Daily Driver didn't seem to have much of an allure, but it's still running today.
Go Figure.....
P
grassyfields
Classic Hondas
Dec 9, 2014 04:04 PM
SpazMan
Jun 11, 2009 06:33 AM
egtony
May 27, 2009 08:26 AM
Dirtyb16
Jan 24, 2009 01:56 PM
