Lost power...what little i had
Ok, basic summary:
Replaced cam seal, and ever since i havent had power what so ever...its enough to barely pull me along but i have no acceleration in any gear but 1st even if i push the pedal to the floor.
D15b7
a6 cam with aem gear adjusted to TDC (4.75 degrees)
z6 intake manifold
obx 4-2-1 header
short ram intake
airmass catback exhaust
z6 tranny
Before i replaced the seal, it had awesome power for a d15. I could pull easy on an LS. Now its hard to accelerate from a kia rio...and that sucks...
D15b7
z6 intake manifold
obx 4-2-1 header
short ram intake
z6 tranny
Check to be sure the cam timing is not a tooth or two off. Set to TDC (at crankshaft) and remove the upper timing belt cover. The two markes should be in line (parallel) with the top of the head.
I have already moved the cam gear a tooth to the left and right. Turning it one more tooth right made it extremely sluggish, and i had to rev it to 2500 to move the car. One tooth to the left made it spark knock even when fully retarded o n the distributor.
Also, i dont have the cover on the upper side, and the marks are even with the head.
I cant seem to figure out what i did.
on that engine there is a timming mark on the bottom of the cam pulley. it should line up with the plastic mark. not the one on the sides. that is your prob.
Ef4doorwagon
13
May 17, 2014 06:09 PM
blacktibby07
May 8, 2011 09:46 AM
