got a new block. need to know what this is for.
Old Mar 8, 2006 | 07:51 PM
hatchbackjdm's Avatar
Default got a new block. need to know what this is for.
the bung in the back of this b18a, right above the oil sending unit is drilled and tapped for something. there is the same casting in my old b18b but it was solid and not drilled. what i need to know is if i need to plug it, im sure i will. and what size plug do i need to use?
Old Mar 8, 2006 | 07:57 PM
Smoke_em's Avatar
From: Inland empire, E.L.A, Douglasville GA, ca, u.s
looks liek someone must have taped it to put a Knock sensor in it same size . .
BTW u donthave to plug it u just haev a spot for ur knock sensor unless u chipped ur ECU with out one
Modified by Smoke_em at 9:38 PM 3/8/2006
Old Mar 8, 2006 | 08:34 PM
bluemax189's Avatar
Default Re: (Smoke_em)
yep, that was for a knock sensor. looks like that block was part of an LS/Vtec swap. The non-vtec b18's did not have knock sensors.
Old Mar 8, 2006 | 08:41 PM
so what do i use to plug it up?
Old Mar 8, 2006 | 08:52 PM
Smoke_em's Avatar
Default Re: (hatchbackjdm)
nothing should not harm it . but if it will make u feel at ease put ur b16 knock sensor with out pluging it in
Old Mar 8, 2006 | 08:59 PM
there isnt coolant or oil or brake fluid or tranny fluid or gas or washer fluid or blinker fluid running through there?
haha thats all the fluids i could think of in a honda
oh yeah power steering fluid but i dont have p/s
Old Mar 8, 2006 | 09:09 PM
Smoke_em's Avatar
lol no there should'nt be. the knock sensor doesnt dtect fluid so is shouldnt have been taped all the way in . knock sensor good for abnormal engine vibration . detonation pinggin Ect ect
Old Mar 9, 2006 | 11:09 AM
Davep's Avatar
Default Re: got a new block. need to know what this is for. (hatchbackjdm)
that port is for the coolent temp sensor. on non-obd engines it's on the back of the block instead of the thermostat housing.
Old Mar 10, 2006 | 08:01 AM
99B16Si's Avatar
Default Re: got a new block. need to know what this is for. (Davep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davep &raquo;</TD></TR><TR><TD CLASS="quote">that port is for the coolent temp sensor. on non-obd engines it's on the back of the block instead of the thermostat housing.</TD></TR></TABLE>
+1, the knock, if there was one, would be above the water pipe
Old Mar 10, 2006 | 09:31 AM
so is it the knock sensor or the coolant sensor?
Old Mar 10, 2006 | 09:47 AM
Davep's Avatar
it's the coolant sensor
Old Mar 10, 2006 | 05:16 PM
Combustion Contraption's Avatar
Coolant sensor.
Also, i highly recommend running the oil line to the head off a sandwich plate in between the filter and the block instead of the tee like that.
Japankid
Welding / Fabrication
Apr 9, 2009 12:35 PM
gen2fanatic
Feb 28, 2007 07:09 PM
tradesalot
Sep 19, 2004 09:23 PM
dose
Oct 22, 2002 04:11 PM
